Author Topic: Air con cooling coil leaked  (Read 20563 times)
Offline ccsSGM
Re: Air con cooling coil leaked
« Reply #20 on: February 20, 2010, 02:33:58 PM »
My got "hisssling...." sound does that mean cooling coil leak too? :confused1:
Same as mine ,,Later u feel the air con is not so cold  ::)
Offline Enzoni
« Reply #21 on: February 20, 2010, 11:09:54 PM »
then finally on a hot day, u find urself enjoying sauna in ur car cos the aircon is blowing warm air...
Offline Toalson
« Reply #22 on: January 20, 2011, 08:49:26 PM »
Mine just checked in the leaking cooling coil....  :nonod: :crycry:
Car only close to 2 years, only a few days shy
Offline ccsSGM
« Reply #23 on: January 20, 2011, 09:43:57 PM »
Under Warrantly, Change it for FOC  :thumbsup:
Offline ccsSGM
« Reply #24 on: January 20, 2011, 09:51:59 PM »
Next step........... Call them to check  Air con blower
Otherwise u will  :crycry:
Offline Toalson
« Reply #25 on: January 20, 2011, 10:23:11 PM »
Below is the status:
RENEW A/C EVAPORATOR,EXPANSION VALVE,THERMOSWITCH, RECEIVER DRIER, VACUUM SYSTEM INCLUDE TOP GAS
Now confused as was told by SA that cooling coil leaking :confused1:
Offline swarovski latio
« Reply #26 on: January 21, 2011, 11:12:37 AM »
Hissing sound is the initial stage of leaking but still can tahan... fyi service coil is using the term of using chemical but infact is class 3 acid to clear the coil but at times some mechanic tends to overlook the timing for the acid to work its way into the coil so tend to damage the coil ... i have done replacement for a few latio n most of the time the coil is the main issue.
« Reply #27 on: January 21, 2011, 11:52:36 AM »
http://www.ehow.com/list_7294487_r134-inhalation-hazards.html
another sign to watch out: you are easily short of breath or sleepy after you drive for some time which never happen before.
Better change the coil else you inhale the aircond gas.
Offline Toalson
« Reply #28 on: January 21, 2011, 09:51:59 PM »
Thanks just got the car and a/c as cool as before :yehyeh:
Let's hope it would last longer this time :(
Offline francislai
« Reply #29 on: January 21, 2011, 11:14:37 PM »
I suspecting my latio has coil leakage problem too.
Aircon was blowing hot air until i top up the gas on 1/1/2011. Today, the car starts blowing hot air again.
However, the warranty has over expired since June 2010 and i have not been servicing in TC.
Appreciate if someone can recommend a workshop to check and possibly replace the coil. Thank
« Reply #30 on: January 22, 2011, 03:22:11 PM »
hmmm last 2 days.. i got these 2 problem appearing....
1) i got this Hissing sound whenever i start my aircon + engage D or R gear..
If i set my fear to Neutral + switch on air con>> no hissing sound..
Is this a sign of cooling coil Dying???
2) at my vehicle commander seat (passenger seat), there is alway this "knocking" sound coming out from the Within the dashboard  whenever i am going at 80km/h
I have remove all items in the my glove compartment, coins/drinks compartment (infront of the gear) and the comparment above radio.. .. STILL GOT that sound leh.
any gurus know what is the cause???
Offline Roy
« Reply #31 on: January 25, 2011, 12:30:07 AM »
i just replaced my cooling coil n air-con filter plus vaccum n top up gas at $380. was told that latio car air-con not very lasting compare to toyota. around 100,000km problems will start to araise. the workshop is at ubi road 1 block 3023A cant remember the name.
Offline kgleo
« Reply #32 on: February 01, 2011, 11:21:48 AM »
Hi, think you talking about Tomika at Ubi Rd 1. My ac also kaput today. Any idea how long the repair takes? Thanks.
Offline Roy
« Reply #33 on: February 01, 2011, 11:14:18 PM »
it takes them about 5hrs to finish the job. U can request to see the spoilt parts. There are some small holes in my old cooling coil due to condensation over the years thus creating the hissing sound. If u are attentative enough u can smell some refrigerator gas coming out from the air con vent. To put it simple. gas leak.
« Last Edit: February 01, 2011, 11:27:35 PM by Roy »
Offline kgleo
« Reply #34 on: February 02, 2011, 08:06:01 AM »
Thanks bro, I sent mine to Mark Cool at Woodlands as it was nearer for me in Mandai. Mine also cooling coil leak, but it only took them an hour to replace, vacuum and renew ac gas.
« Reply #35 on: April 20, 2011, 02:47:16 PM »
Today Tan Chong diagnose my aircon coil leaking and need to change, Total cost is $440 nett ,inclusive of gas top up. Seem to be a good price from agent.
« Reply #36 on: April 21, 2011, 09:11:29 PM »
$440 is indeed a reasonable price given dat its done by agent, do check wif them wat is the warranty period given by them...
Offline ccsSGM
« Reply #37 on: April 21, 2011, 10:13:17 PM »
Request for Goodwill claim,  FOC labour charge  :thumbsup:
Offline kgleo
« Reply #38 on: April 22, 2011, 08:34:33 AM »
That's a very good deal. Mine was done at Mark Cool and cost me $460 with 3 months warranty. :unsure:
« Reply #39 on: April 25, 2011, 03:50:20 PM »
I think not all will get it, especially now they have promo on the aircon coil. Also must be handsome....  ;D
PS, to add they also change the "Thermostat amplifier Sensor" which cost $40++. So the actual cost for the change in aircon coil is around $400...
« Last Edit: April 25, 2011, 03:58:46 PM by Ender »
