Author Topic: Those who experienced spoilt air con & alternator come in here  (Read 52522 times)
Re: Those who experienced spoilt air con & alternator come in here
« Reply #100 on: April 24, 2013, 10:38:05 PM »
I have since put a thermometer at the vent - that way, I can observe the temperature of the air that is being blown into the cabin
Offline Dec7f
« Reply #101 on: April 30, 2013, 10:58:05 PM »
Any bros & sista able to share on below problems?
i also experience (1). every morning or after parking for a long time, the start up of the air con will be super loud
Offline bruceneo
« Reply #102 on: June 23, 2013, 09:14:46 AM »
Continuing my air-con saga:
4 years 8 months - Cooling coil leaking replaced.
5 years 6 months - Now sometime not cold. Check by workshop found no leak. Mechanic in JB comment the compressor may need to change (RM400 for recon unit). I suspect the magnetic clutch not good sometime not engage because when you press the "air-con" button, the rpm went up but do not hear the distinctive magnetic clutch engage "teac" sound. Finally found contact loose next day. Unplug and plug in ok.
6 years 4 months - Milage about 120k. Yesterday the compressor completely jammed-up on TPE. Really shitty because of the haze and workshop is closed for the weekend.
Offline NLatio
« Reply #103 on: June 25, 2013, 05:01:55 PM »
My aircon compressor up loory on 4th or 5th year....  :blink:
Now I got another problem.... sorry not familiar with Cars part.... there is a part behind the glove compartment that is controlling the aircon, is faulty.... I can on the aircon but totally no wind come out..... the mechanic replace a few time but some only last a day.....  :confused1:... say the connection not good.... kao..... each cost $155++..... drive 1 day change 1 time I will be broke....  :crying:........ though till now, he change for free, but claim the supplier will not honour the changing..... told me common problem... kao.... how?? If go TC, sure kena chop into pieces....
« Reply #104 on: June 25, 2013, 09:26:15 PM »
hi bro,it could be the blower faulty,causing the module to burn again.the module need the blower to cool down whenever u on the a/c.did't the mechanics check the blower motor????
Offline NLatio
« Reply #105 on: June 25, 2013, 09:31:39 PM »
Hi Bro, apparantly not......  :nonod:...... think will drop by your place when I find the time..... how long it take to repair??
Btw,how much to change the blower??
Offline kt
  • Car Color: Amethyst Grey
« Reply #106 on: June 27, 2013, 08:55:35 AM »
1. Windmill75   spoilt when car is 3.5 yrs old
2. ccsSGM      cooling fan gas leak after servicing 38mth old
3. dsrio           spoilt when car just pass 3 years warranty, foc goodwill
4. papajo82     spoilt recently. car 2 years 1 month
5. enzoni         replaced leaking cooling coil when car is 3yr 8mth old
6. jonpaul0104 replaced aircon compressor when car is 4yr 2mth old
7. zippy          replaced a/c compressor today. Car is 1yr 6mth old.
8. marcus        air-con not cold since day 1.
9. priyana       replaced aircon compressor when care is 3yr 3mth old (at outside workshop since TCM quote higher)
10. Jazonthemove replace cooling coil leaking @ 2yr old
11. Jazonthemove replace a/c friday 12.02.2010 @ 2yr 11mth
12. junchen air con not cold when car is 1 yr old. Replace with a new aircon compressor.
13. sengkang replace compressor @ 2 yrs 9 mths
14. nakshire ac forever not cold. TC say i too kiasu, but i really dun feel that its cold...
15. lyh1280 changed twice, once under warranty at ~80K, once after warranty over ~140K...
16. cm2109 changed at abt car 1.8yrs(34k), now same problem again car just after 3yrs
(64k), out of warranty now pending reply from to Nissan Japan.
17. Kanzo replaced a/c evaporater assy ( a/c coil ) when car 2yrs 11mths and 20 days old.. just in time
18. andromeda2000 replaced compressor (under warranty) last week when i complaint that engine is noisy @ 1.5 yr old (30k)
19. legan replaced compressor (under warranty) last week when i complaint that engine is noisy @ 1.5 yr old (50k)
20. ksliew: compressor replaced after 2yrs. Loud whirring noise from engine compartment.
21. fmz : aircon gas leak. noise since early feb. gone today. 41mths
22. a40x: aircon gas leak and blowing hot air. noise since last week. (warranty just over by 2 weeks)
23. coolant gas leak after 2 yrs. 3rd times topup now pending for cooling coil replacement. Today, 40 mths
24. CSM: Compressor and Air con gone after 2.5yrs
25. Stealthy: Aircon not cold - evaporator coil leak after 2.5yrs
26. Archie_baby   Replace evaporator assy after 45 months
27. Phant : REPLACE AIR COND CONDENSER ASSY -WARRANTY
     -   RENEW COMPRESSOR ASSY -WARRANTY
          1yr +
    ->   CHK AIR CON NOT COLD - RENEW AIR CON COOLING COIL ASSY = 2 yrs+
28. Xmen:Replace evaporator coil leak after 3.5yrs. Disappointed with Nissan quality
29. Mat: Replaced car compresor in Feb after 4.5 yrs. but now car is having problem with ac dont know will replace what next
30. dsrio: cooiling coil replaced at 3.5 years.
31. detach8: cooling coil replaced at 1.5 years (approx 40,000km)
32. Homyson:  comperssor noise, near to 5years (61km)
33. Leo: Cooling coil spoilt after 90K km or 3 yrs 5 months.
34. Kel: Gas leaked, not cold; Coil broke - 4yr 6 months...replaced at TCM
35. pizzaboy: replaced a/c compressor 18mths, replaced coolin coil 39 mths
36. KT : replaced cooling coil - car ard 4 years old. Compressor quite noisy when starting engine. Think also about to up lorry. Now just waiting for it to totally die before replacing it. Finally replaced my compressor yesterday. Car around 6 years old. Air con been working on and off for the last 2 months and I finally had enough of its lady tantrum
37. Hirofumi : Aircon not cold when driving upslope. after 2 years 4 mths... TCM say no problem..
38. ckmckm: compressor spoil due to cooling coil change. cooling coil change due to leaking. bad service from Tan Chong Ubi. Small problem become big problem. Change when car about 5 years 6 month old
40. Everince: Replaced the Compressor after 3yr 3 mth by TCM. My ride so far approaching 7 year...aircon still ok as long as replace air con filter regularly...
41. 1258:air con not cold when 2.5yrs went buck to TC to get it done, but now just one yr later it cum buck again.....
Offline tsc2828
« Reply #107 on: July 07, 2013, 11:53:15 AM »
          1yr +
42, tsc2828 : Replaced both a/c compressor and cooling coil after 3.5 years
