Author Topic: 1 tyre different width..  (Read 10511 times)
Offline jalan
« on: March 29, 2010, 06:13:58 PM »
My Latio front right stocked Toyo tyre
Original Toyo 185/65R15 , running for abt 20K ...punctured and
Was changed to Good year 195/60R15 ( 1pc ),
i ask for similar size tyre but tyre shop say no similar size..
mechanic ask me use 195/60R15 ...saying no difference...can be use..
i was driving with it for close to 1 month ... os far no problem...
Any advice on the odd 1 out tyre size,,, will it cause other tyres to wear out faster ???
Offline tchekchuan
Re: 1 tyre different width..
« Reply #1 on: March 29, 2010, 07:12:40 PM »
your goodyear tyre might wear off faster as the loads are upon the new tyre.
Offline CamholicX
  • Redline (6000 rpm)
« Reply #2 on: March 29, 2010, 08:37:31 PM »
try wearing diff type of shoes...
« Reply #3 on: March 29, 2010, 10:44:30 PM »
Which workshop so genius?  Let us know to avoid.
« Reply #4 on: March 29, 2010, 10:46:40 PM »
How come he never ask you to use your spare boot tyre instead if you can accept the difference.
« Reply #5 on: March 30, 2010, 01:19:10 AM »
195/60-15 has a 1.05% diff according to tyre calculator, so there suppose to have a difference as your new tyre radius and circumference is smaller, turning should have a little impact. This is first time I hear of your case as 1 tyre difference, usually min 2 tyre differences either front or rear.
Original tire
  Sidewall: 4.73 in
  Radius: 12.23 in
  Diameter: 24.47 in
  Circumf: 76.87 in
  Revs/mile: 824.25
New Tire
  Sidewall: 4.61 in
  Radius: 12.11 in
  Diameter: 24.21 in
  Circumf: 76.07 in
  Revs/mile: 832.96
Offline rongshu
« Reply #6 on: March 30, 2010, 09:21:14 AM »
spare tyre is only for emergency short distance use, not for regular use i think.
« Reply #7 on: March 30, 2010, 09:34:13 AM »
tat tyre shop simply just wanna to earn ur $$ and don care the rest, altho no major issue, but the driver not them
Offline jalan
« Reply #8 on: March 30, 2010, 11:11:02 AM »
P.H. at AMK...
Offline jalan
« Reply #9 on: March 30, 2010, 11:13:24 AM »
my spare tyre also J50 toyo mah ...just those Taxi kind of rims..
Offline jalan
« Reply #10 on: March 30, 2010, 11:19:19 AM »
i agree...i believe that model of gd year tyre must be most profitable or too much stocked...
« Reply #11 on: March 30, 2010, 11:28:12 AM »
How much you pay for 1 tyre in P.H?
Maybe you can check with arrow tyre as i see they have a wide range of toyo tyres when i change my battery there.
« Reply #12 on: March 30, 2010, 11:29:06 AM »
Gosh~ that jewellery tyre shop again.
Offline nzmg
« Reply #13 on: March 30, 2010, 11:32:59 AM »
If you don't want to change the whole set of 4, the norm is at least change in pairs (ie. 2 tyres).
For your case, change the front 2 tyres.
Offline jalan
« Reply #14 on: March 30, 2010, 12:01:13 PM »
thanks bro ,for your information.
after changing the gd year 195 size tyre .. and drive for 2 weeks +
, my rear right stocked tyre got punctured ...
now i am confused whether it is the incorrect size front tyre that cause the rear tyre to get punctured easier or i am just damn unlucky..
should i change back the front tyre to 185 size as i will be going for my 20K servicing...
better for tyre rotating ?
Offline jalan
« Reply #15 on: March 30, 2010, 12:02:43 PM »
S$85 for Gd year eagle NCT-1... this shld be market price rite?
Offline jalan
« Reply #16 on: March 30, 2010, 03:06:42 PM »
should i change out the fairly new gd year 195/60R15  ? back to a new toyo 185/65R15 ...
or should i change out the old left front toyo 185/65R15 to make both front tyre 195/60R15   ??
what will be the better choice ?
« Reply #17 on: March 30, 2010, 03:16:35 PM »
Dun worry, tyre punctured has nothing to do with your front tyre incorrect size, even all 4 same will encounter tyre puncture too.
Yes, should change back to the same size for tyre rotation, recommended for safety as well.
Offline jalan
« Reply #18 on: March 30, 2010, 03:40:48 PM »
thanks bro ....for your kind advice.. :thumbsup:
« Reply #19 on: March 30, 2010, 04:27:03 PM »
wondering if the punctures are located in the treads or the sidewalls?
if the punctures are located in the treads, they can be repaired
