Author Topic: Can advise on inspection?  (Read 16273 times)
Offline kenny59
  • C'mOm Let'S Play...
« on: July 07, 2010, 08:46:14 AM »
Hi brothers,do any of the bro or sis here send in their car in for inspection with angeleyes headlamp n tinted signal lamp?Pls advise or share because my car is due for inspection by end july. :smile:
Offline hwlee
  • Honda
Re: Can advise on inspection?
« Reply #1 on: July 07, 2010, 09:40:46 AM »
Kenny, any lamp with tinted different color that LTA allowed is illegal. You better take it off before Inspection.
Offline kenny59
« Reply #2 on: July 07, 2010, 10:08:07 AM »
Ok thxs,mayb will remove the headlamp but tail lamp will remain cos Ryan pass his inspection with that clear tail lamp.;-)
Offline hwlee
  • Honda
« Reply #3 on: July 07, 2010, 11:18:02 AM »
I think Angel Eye also allowed. As long as no HID kit attached. :D
« Reply #4 on: July 07, 2010, 12:19:26 PM »
I dont believe kenny doesn't know other alt way to go thru inspection...
« Reply #5 on: July 07, 2010, 12:23:38 PM »
but the Audi can on their front HID in board day light  :confused1:
« Reply #6 on: July 07, 2010, 03:04:14 PM »
What about eyelid, can pass inspection ?
Offline althor
« Reply #7 on: July 07, 2010, 04:07:14 PM »
Taken from:
http://www.onemotoring.com.sg/publish/onemotoring/en/lta_information_guidelines/modifications_and_vehoffences/modification_guide/modification_not_allowed.html#MainPar_0036
Vehicles should only be fitted with factory fitted HID lamps as they are designed to meet internationally recognised standards. Aftermarket HID lamp kits retrofitted into existing headlamps may cause unwanted glare when used. Therefore, installation of these kits are not allowed.
With effect from 1 January 2010, LTA will require all newly registered vehicles, except motorcycles, fitted with HID headlamps to be equipped with an auto-levelling feature.
All vehicle lamps must meet internationally recognised standards. Tinting or masking of these lamps is not allowed as it may adversely affect their performance.
Offline hwlee
  • Honda
« Reply #8 on: July 07, 2010, 04:17:16 PM »
100% agree. But Angel Eye is not HID lamps leh. So, can use back normal halogen bulb for your Angel Eye then pass inspection?
Offline PTC77
  • Nismo LaTIo
« Reply #9 on: July 07, 2010, 04:52:03 PM »
May i propose since Bro #nakshire is selling HID at the forum  :devil2:, how about engaging his exclusive service to remove & assembly back the HID light prior to before & after LTA inspection at a cost deem reasonable for both parties?  ;D
Offline kenny59
« Reply #10 on: July 07, 2010, 07:33:42 PM »
Removing of hid n replacing back the normal halogen bulb is small job for me,what i mean is the aftermarket headlamp which is angeleyes with projector ball...Wonder can pass anot if I just change back to halogen without changing the headlamp.
NSMAN:Now reli very strict after the case on bride of inspection centre inspector la,if not i won't have to go through some much hassle. :D
Offline hwlee
  • Honda
« Reply #11 on: July 07, 2010, 09:11:50 PM »
Kenny, the projector at the angeleye is not design for HID. It still using H7 halogen bulb, I'm very sure. They mention very clearly regarding install a "aftermarket HID lamp" is not allowed if it doesn't meet the "Internationally recognised standards". If you take out your HID and put back halogen bulb, your angeleyes is ONLY an "aftermarket headlamp".. As I know, some cars original come with projector lens but not HID lor. Cheers
Offline kenny59
« Reply #12 on: July 08, 2010, 12:41:23 AM »
Think even aftermarket headlamp is not approved ESP if it black base. :(
Offline hwlee
  • Honda
« Reply #13 on: July 08, 2010, 09:28:39 AM »
Nissan NV200 and mostly Volkswagen cars are using black-based headlamp.  :devil2:
Tell inspectors that you make your housing to black-based is to reduce the glare lor.  :D
If aftermarket headlamp can not pass the inspection, the aftermarket taillamp also can not pass inspection liao...  :D
p/s: If i am not mistaken, the glass of your angeleyes is printed with SAE(http://www.sae.org/) symbols.
« Reply #14 on: July 08, 2010, 09:58:38 AM »
seems like you know alot hor hw, have you passed your inspection with ur angeleyes headlamp?
Offline hwlee
  • Honda
« Reply #15 on: July 08, 2010, 10:30:43 AM »
Bro, I just passed my inspection last May. I don't have angeleyes for inspection.  :bleh:
Btw, I just wonder why aftermarket taillamp can passed but not the angeleyes which without HID lor.  :D
Offline kenny59
« Reply #16 on: July 08, 2010, 12:04:26 PM »
Think is due to the headlight angel cos the lamp we bring in is from taiwan n they belong to left hand drive n therefore will shine against driver that is opposite us.As for tail lamp is bro kyorei said he passed his inspection with that tail lamp lor.
Offline hwlee
  • Honda
« Reply #17 on: July 08, 2010, 01:23:02 PM »
I start wondering either you check the light pattern of your angeleyes properly or not. It will not glare/shine against driver that is opposite us lor. Tonight, find a flat wall in the MSCP, open your low beam (as Inspection no checking on high beam and fog light), see the like pattern of your angeleyes.
you suppose to see your angeleyes low beam light pattern is like below:
  \__\__  <-- this glare people on your left hand side
if you want to shine people from opposite..i think you need to mode the cut off point like this
__/__/   <-- this glare people on your right hand side
Unless you aim your headlight to shoot the bird on tree...then use stock headlamp also will fail inspection. :)
Offline nakshire
  • I'm a cute boy ok!
« Reply #18 on: July 08, 2010, 02:06:28 PM »
alamak bros, now i practicum leh... no time to do HID things liao... ask ryan help out with this, he is the pro man...
Offline totallypatrick
« Reply #19 on: July 08, 2010, 02:33:44 PM »
bro i tot u say changing car? quickly change before inspection then no headache :p
