Author Topic: AIr-con cooling coil leaks, needs advice where is good workshop for replace?  (Read 10779 times)
Offline clsdch
Hi Latio owners,
My 4 years old latio air-con blowing warm air. After top up the air-con gas, it was good for 3 weeks. When the problem occured, I sent back to TCM for check, they said that cooling coil is defective.
Could you advice me where can I get the cooling coil replaced? Any ideas, how much it cost?
Thanks.
i did mine at autoaid, toh guan road east, about S$400.
some bros did at tomiko at ubi, price i not sure
Offline clsdch
Thanks dsrio.
My car air-con after top the gas it work well again. One week plus, air-con still cooling. When the problem happen again, I will send my car for air-con check and replace the cooling coil, if that is the real defective.
Offline Huatster888
  • TAI KAY LAI HUAT AR!!!
so what symtoms do u hve when u on ur aircon??is the hissing sound normal??
Offline clsdch
Very light hissing sound, when blowing warm air. After top up gas at TCM, air-con is cooling, did not hear any hissing sound. Air-con is working well for last 12 days.
Could be your evaporator unit, I have experienced once when the drying agent in the evaporator unit breaks down and block up the valve, after you off the aircon for a while it functions normal when you on it again but problem will come back again.
Offline Huatster888
tanks.....i will monitor mine.....
Offline clsdch
During the problem occurs, I have off the air-con for 5 to 10 mins and then ON the air-con, it does not help. Until I went to TCM top up gas and the air-con cooling again. Today, the car air-con still working fine.
Just guessing is that really a leaks in cooling unit!
Offline Huatster888
up till now air con is cold but hissing sound still there some times its reali loud.....
hissing sound is due to cooling coil leakin, do u encounter any bitter smell comin out from the vents?
if u do its better u get ur coil replaced instead of toppin-up gas as it will not solve the prob permanantly.
Offline Huatster888
Re: AIr-con cooling coil leaks, needs advice where is good workshop for replace?
« Reply #10 on: September 01, 2010, 01:14:15 PM »
no bitter smell coming out from vents.....
tank u all 4 the tips n advices , just wana find out if the coil reali spoil liao.so this hissing sound is firm tat the coil is leaking??
but rite now dun hve so much money to get it fix.
Offline yaya_bear
  • Latio DOG!!!!!!!
« Reply #11 on: September 02, 2010, 09:38:29 AM »
Hi All, I also experiencing my air con having the hissing sound & experiencing foul smell... at first i tot it is my smelly feet  :yehyeh: ...
Can anyone help by recommending cheap n reliable workshop ?
Cheers ... :crycry:
Don't pray prey !!! Ur Car cannot win me in Slowest pick up.......
Offline clsdch
« Reply #12 on: September 05, 2010, 10:43:01 PM »
Latio Brother share with us that "i did mine at autoaid, toh guan road east, about S$400.
some bros did at tomiko at ubi, price i not sure".
Offline swarovski latio
« Reply #13 on: September 07, 2010, 01:12:18 AM »
bro since few brother r facing this issue let me try to speak to few of my workshop mechanics n hope to get a good price for u guys.... as i am supplying cooling coil, compressor , filter to some of them try to get it maybe less than 350 inclusive of labour , vacumming , new gas n of course new coil ! give me 1 or 2 days to get back to u guys !
« Reply #14 on: September 07, 2010, 04:18:55 PM »
YOU'RE THE MAN!!!
« Reply #15 on: September 08, 2010, 12:09:42 AM »
WoW at a cost of less than 35O bucks is a steal man, many spent between 400 - 500 to get their coil replaced.
« Reply #16 on: September 09, 2010, 12:37:29 AM »
Bro pricing will be revert to me by tomorrow by 4 workshop .... stay tune
« Reply #17 on: September 10, 2010, 11:13:17 AM »
pricing up ... changing of coil itself will be at 350 nett
if changing of blower valve n filter together will be at 380
Offline link2563
« Reply #18 on: September 11, 2010, 08:11:17 AM »
Hi swarovski latio,
Good Morning.
Could you let us know the workshop address and contact number?
Many Thanks.
« Reply #19 on: September 11, 2010, 01:28:15 PM »
the workshop is at kaki bukit autobay as for the contact u will have to contact me coz i will be supplying the coil etc to the mechanics ...... they r only in charge of the labouring so pm me .... by the way u have pm
