Author Topic: AIr-con cooling coil leaks, needs advice where is good workshop for replace?  (Read 10780 times)
Offline clsdch
Re: AIr-con cooling coil leaks, needs advice where is good workshop for replace?
« Reply #20 on: September 18, 2010, 11:47:32 AM »
Thanks for possible supply cooling coil.
My car air-con working well for a month, the last gas top up was one month ago. Now, I am not too sure is that really the cooling coil problem?
Anyone experience the cooling coil takes more than a month to leaks and air-con become blow warm air?
Offline foofam77
may i know how much TCM charge for just purely topping up of the aircon gas?
my ride is near 4 yrs and am under TCMP now.
thanks
Offline blurearth
HI ALL, I AM HAVING THE SAME PROBLEM WITH MY LATIO.  Same light hissing sound then i went to tan chong ubi to service, they top up the gas and become cold again only for two days. Then start blowing hot air again. my latio 3years 10 months. Guess around 4years latio will start having this problem. The ******** tan chong mechanic cant find a reason for the hissing sound and tell me to change the whole aircon unit for $2.4k..faintz..
how come TC mechanic/SA do not know that a pressure test will show if there is a leak?
Offline blurearth
duno leh..going to complain to tcm tomolo c wat they say. by the way, swaroski how do i contact you if i need to change the cooling coil? Still $350 rite?
Offline blurearth
pricing up ... changing of coil itself will be at 350 nett
if changing of blower valve n filter together will be at 380
hi swarovski! is the deal $350 include labour and cleaning of the condenser unit?  I s it still available?
Offline sunnyong
how about air con compressor?? do u have lobang n how much it cost??
