Author Topic: 2nd hand Latio premium - Tweeter no sound???  (Read 4434 times)
Offline dareindie
« on: August 27, 2010, 05:02:46 PM »
Hi all bros & siss,
Just got a 2nd hand Latio and noticed the 2 tweeters on near the front windscreen didn't have sound. Check the stock player and it only indicates x4 output. So was wondering bros' with premium, how to turn that on?
Also, how does the plasma ion air-con works? Mine is always showing CLEAN. So does it need to be cleaned or is there a way to turn ioniser on?
Thanks!
Offline rainboy
Re: 2nd hand Latio premium - Tweeter no sound???
« Reply #1 on: August 30, 2010, 11:04:50 PM »
The aircon will automatically alternate between clean and ion modes.  The interval is about 15mins.  No way to manually select the mode.
Offline dareindie
« Reply #2 on: August 31, 2010, 01:49:38 PM »
Hey rainboy,
Thanks for the info!
Offline eagleyes647
  • eagle eyes
« Reply #3 on: August 31, 2010, 02:16:21 PM »
Hey Bro Dareindie
The reason for your tweeter no sound, could be there's no tweeter inside or the wiring loose. The 4x output is for our front 2 n back 2 speakers, tweeter can jus tab on any of the output.
Offline CamholicX
  • Redline (6000 rpm)
« Reply #4 on: August 31, 2010, 10:17:31 PM »
dont ever tap yr tweeter to yr mid bass. the frequency will blow yr tweeter once u on the vol.
« Reply #5 on: August 31, 2010, 11:06:33 PM »
as far as i knw only the premium model comes with tweeters, most prob previous owner did not connect the wirings to it or he might have removed the pair of tweeters completely
Offline swarovski latio
« Reply #6 on: September 01, 2010, 08:59:25 PM »
premium version tweeter does have condenser affix with it so will not blow ..... if u r having tweeter without condenser n having direct to a amp.... the coil will be burnt off.......
Offline jovially
« Reply #7 on: September 02, 2010, 08:51:52 AM »
Is it correct that only when play cD, then tweeter will have sound? no sound for normal radio?
« Reply #8 on: September 03, 2010, 03:53:50 PM »
Tweeter is for Hi frequency.
Audio equipment like speaker generate the sound via the frequency been set. Notice the freq required.
It does not mean radio or anything other things.
Same thing like woofer, it only accept low frequency.
That's some people have the equaliser to tune the sound. Also, that's where cross over comes in to separate the frequency to mid bass and tweeter.
Look at ur hi fi system. Some have 1 tweeter and 1 mid bass and some 1 tweeter and 2 more cones. Different frequency set.
