Author Topic: Wheel realignment - must after rotor change?  (Read 3044 times)
Offline cjkannan
« on: October 27, 2010, 06:47:42 PM »
bros,
need advice if I should go for wheel realignment/ balancing after the rotor change.
I recently changed to a new rotor plus brake shoes and not sure if I need to do the above. is it a must do or only do if any problem?
thanks
Offline b3nn
Re: Wheel realignment - must after rotor change?
« Reply #1 on: October 27, 2010, 07:43:21 PM »
bros,
thanks
Well that actually depends. If you were present during the installation and oversaw the whole process it's up to your judgement to decide if the integrity of the steering column etc has been compromised. In my personal opinion, you need not do a realignment unless you have a camber kit, then you may need to check the camber angle.
Digressing; did you install an aftermarket rotor?
Offline cjkannan
« Reply #2 on: October 27, 2010, 10:06:05 PM »
ok. thanks for the feedback.  yes I I stalled after market kit 285 rotor and I am happy with it in terms of  response. the installer is also of the opinion I need not do realignment. just wanted to double confirm.
« Reply #3 on: October 28, 2010, 06:03:36 PM »
if you have a road trip to malaysia, just do it at tyre shop for RM30.
