Author Topic: Wheel realignment after front-shock changed (?)  (Read 4863 times)
Offline pest11
« on: November 03, 2010, 09:13:02 AM »
Hi All,
Wheel alignment required after front-shock changed to KYB ?
Tks in advance !!
Offline bulleth9
Re: Wheel realignment after front-shock changed (?)
« Reply #1 on: November 03, 2010, 03:45:11 PM »
Yes its needed as they had to remove screws that hold the front transmission together.
Offline pest11
« Reply #2 on: November 04, 2010, 04:23:01 PM »
thank you !!!
Offline pest11
« Reply #3 on: November 10, 2010, 10:00:19 PM »
oh another thing ..... since replacing to KYB gas-shock, driving is firmer ......... but notice there is a "tok" sound on the front-right and ONLY when going over humps, what's this ?? what need to be replaced ? Price?
Tks in advance !!
« Reply #4 on: November 10, 2010, 10:13:23 PM »
I am still waiting to change my shock. I am going to change the lower arm joint together with shock then do wheel alignment at one go.
Did you check the condition of your lower arm joint? a ball-joint thing  behind your wheel hub. I remember a bro posted some pic of it.
Offline pest11
« Reply #5 on: November 10, 2010, 11:06:17 PM »
the ball-joint on lower arm-joint .... ok noted wif tks .... will ask mechanic to check again ... tks.
Offline pest11
« Reply #6 on: December 30, 2010, 02:31:26 AM »
after months of bz schedule, manage to squeeze some time today and get it replaced;
1.  lower arm-joint both side
2.  rubber mounting both side
driving, braking, over humps  is :thumbsup:
but workshop say due to KYB-gas-shock is firmer than stock-shock, therefore might reduce the lifespan of arm-joint & rubber mounting  :unsure:
Have a great New Yr !!
