Author Topic: Intermittent Air Con Problem (advice needed)  (Read 3635 times)
Offline coffeeshake
« on: January 11, 2011, 02:58:37 PM »
hello all, need some of your advice on the following
recently, my air con is blowing out warm air during normal drive.. my setting is at 24deg and the air con could be cold but then maybe for around 10-15 seconds, some warm air will come out.
is it because the air outside that is colder than the air con inside the car that causes it or should i change my filter or send back tan chong?
appreciate any comments  :D
Offline ccsSGM
Re: Intermittent Air Con Problem (advice needed)
« Reply #1 on: January 11, 2011, 06:50:36 PM »
Maybe air con coil spolit
Offline coffeeshake
« Reply #2 on: January 11, 2011, 11:52:02 PM »
hey, thanks for the reply.
is tht covered under warranty? r u aware if we buy air filter from tan chong, its at acheaper rate?
Offline nzmg
« Reply #3 on: January 12, 2011, 01:15:39 PM »
if you set the temperature lower (say.. 20 degC), does your aircon still blow hot air?
Offline coffeeshake
« Reply #4 on: January 12, 2011, 05:43:38 PM »
oh... never try... but if i set lower to around 22, no warm air..
Offline nzmg
« Reply #5 on: January 19, 2011, 02:25:42 PM »
i suspect it is due to low temperature outside the car (eg. when it's cold and raining).
Your aircon blow hot air to maintain your set temp of 24degC since it detect a low temp at the thermostat.
I suggest just set at a lower temperature (20-22 degC) and set fan speed at low.  No need to send the car for checkup unless you still get hot air blowing.
I suspect if you send back to TC, they may tell you compressor is weak and "recommend" to change (>$1k).
