Author Topic: Side indicator faulty  (Read 3213 times)
Offline fessm
    • Shopping for ladies
  • Car Color: Red
« on: May 27, 2011, 09:41:42 AM »
My ride's side indicator is faulty.
I discovered the indicator's casing is loose while washing car.
I think water has seeped in and it is not working anymore.  :(
Anybody has workshop in the west area to recommend for servicing this?
What is the price range like?
Thanks  :yehyeh:
Re: Side indicator faulty
« Reply #1 on: May 27, 2011, 09:43:06 PM »
Call autoaid for a quotation
Thanks  :yehyeh:
« Reply #2 on: May 31, 2011, 06:04:53 PM »
Autoaid?
http://www.sgcarmart.com/directory/merchant.php?MID=12707
if you can shake the signal light left and right then the clip for the side signal light may be damage. you can change a new set or just use double sided tape to secure it. To remove it I think you need to access from the back (from wheel arch). If the previous workshop try to peel it off from front then they may crack the clip in the process.
for you case maybe just a light bulb replacement will do.
Offline fessm
  • Car Color: Red
« Reply #3 on: June 01, 2011, 01:30:55 PM »
Ok, noted
Thanks  ;D
