Author Topic: Trunk Light  (Read 6175 times)
Offline vinzlee
  • Look ahead of situation
  • Car Color: Silver
Trunk Light
« on: June 24, 2011, 10:23:05 AM »
The trunk light is located within the boot compartment.  There is a white plastic cap size of 50 cents.  To open the plastic cap, there is a catch that keep the cap in place.  Peel the tip of the catch to unlock the cap.  Once cap unlock, the bulb can be removed by pulling/unplug straight downward.  Just for sharing.
Offline ironkiat
  • Car Color: White
Re: Trunk Light
« Reply #1 on: June 26, 2011, 01:10:51 AM »
 :thumbsup: Thanks for posting this! was thinking of changing the trunk light to LED ones, the current orange light super not bright.
Offline jovially
Re: Trunk Light
« Reply #2 on: June 26, 2011, 08:29:59 AM »
brother, any photos to share? thanks
Offline vinzlee
  • Car Color: Silver
Re: Trunk Light
« Reply #3 on: June 28, 2011, 06:07:41 PM »
Give me some time coz need good lighting to capture the image/details.  When I refer to the manual did not know how to open it until I used a screwdriver to pry it open and realised the correct way to open as per explained earlier.
ironkiat,
Wow didn't know there is LED bulb available, agreed that the current bulb is kinda dim.  If you manage to find LED bulb, please share with us....many thanks.
Re: Trunk Light
« Reply #4 on: June 28, 2011, 09:09:40 PM »
Uses the normal T10 bulbs, same as the pole lights.
Offline quirky
Re: Trunk Light
« Reply #5 on: June 28, 2011, 10:47:43 PM »
Will changing the trunk lights to LED lights void your insurance?? :D
Offline vinzlee
  • Car Color: Silver
Re: Trunk Light
« Reply #6 on: June 29, 2011, 01:15:20 PM »
This is how you access to the trunk light socket.
Offline vinzlee
  • Car Color: Silver
Re: Trunk Light
« Reply #7 on: June 29, 2011, 01:29:24 PM »
For brighter T10 bulb,  installer needs to watch out the loading for trunk light is 3.4 watts only, anything more may blow your fuse.
Offline edwin643
  • Car Color: Silver
Re: Trunk Light
« Reply #8 on: July 01, 2011, 12:29:48 PM »
[/quote
Hello CustomGolf - E-Rev @ Northlink carry LED  T10 at SGD7.
Pls share, where elso can I buy these. BTW, can I use this T10 to replace the cabin light bulb.
Edwin
Offline valles
  • Car Color: White
Re: Trunk Light
« Reply #9 on: May 14, 2012, 01:05:25 PM »
My apologies for bumping up such an old thread.
Could any bros please advise what is the connector for this trunk light?
I'm thinking of DIY changing it to LED hence need to know the corrector connector type. Festoon? BA9S or T10?
Thanks.
Offline IvanL
  • Car Color: Grey
Re: Trunk Light
« Reply #10 on: May 14, 2012, 08:46:17 PM »
Hi bro, I bought my led boot compartment lights from here...
http://list.gmarket.com.sg/item/WHITE-LED-18SMD-AND-36SMD-TYPE/404319429
DIY and connected using the squeezy thing. Not sure what connection is that... but it comes with the squeezy thing and a T10 connector together with it...
After 4 mths of DIY its  :thumbsup:
Offline valles
  • Car Color: White
Re: Trunk Light
« Reply #11 on: May 14, 2012, 09:53:31 PM »
Thanks bro for confirming the connector. That's known as festoon connector by the way.
Cheers.
