Author Topic: need help suddenly engine die  (Read 4041 times)
Offline Raymond Koo
« on: June 28, 2011, 11:23:33 AM »
Yesterday I driving n my car suddenly die but u can start back the car. This is my 1st time like this. And I don't know y let said I open radio n signal stop beside the roads, after 10 minutes my car cannot start, need jump start. Anyone got this problem... I dont know is it my battery start Kong or something wrong for my car electronic system. I was driving Nissan latio sport 1.6 2007 years. Thanx for the  help n info..
Re: need help suddenly engine die
« Reply #1 on: June 28, 2011, 03:50:00 PM »
When is the last time you change your battery? Battery usually last about 2yrs, though my last Amaron last more than 2.5 yrs.
From your description, seems like its the battery fault.
Offline vinzlee
  • Look ahead of situation
  • Car Color: Silver
« Reply #2 on: June 28, 2011, 06:35:04 PM »
Need to check your battery water, if the water level is too low, can affect your battery performance.  Use distilled water to top it up.
Your battery is more than 3 years old,  it is time to replace it.
« Reply #3 on: June 28, 2011, 11:00:42 PM »
most likely it is ur battery too weak already.get it changed and everything ok liao.
Offline Raymond Koo
« Reply #4 on: June 28, 2011, 11:34:26 PM »
okok i chnage the battery 1st thanx a lot
« Reply #5 on: June 29, 2011, 08:14:25 AM »
from my experience, if can crank but cannot start, means battery problem. If no cranking sound, then maybe starter motor problem.
If while driving than engine die off, maybe alternator, MAF sensor etc problem.....
as far as I know, battery is no use once car started cos alternator provides all the current needed eg. charge battery
