Author Topic: Improved car performance noted aft batt change  (Read 2255 times)
« on: July 17, 2011, 01:37:04 PM »
I dont know how to describe in much detail much as a daily user of my car noticed before the batt change car was like "shivering" whenever i slow down the drive like in car parks where u slow really down to negotiate in tight spaces, then pick up also sluggish, while at junction car also shivers when aircon kicks in
After batt change symptoms went away n car felt "renewed"
The batt was installed with my engine running, thus i believe ECU was not resetted, then i could be wrong need some bros verification
But in short car batt change somewhat make the car drive feels good n shivering symptoms during idle n slow drive disappears
Was using Indigo batt from TCM lasted only 1yr 4 mnths
Changed to Varta Blue Dynamic 45aH
Hope some bros n sis knowledgeable to shed some light on this observation
Be monitoring the FC to see if there any increase in efficiency coz i somewhat feel it is better now
Offline m_k_tang
Re: Improved car performance noted aft batt change
« Reply #1 on: July 19, 2011, 10:04:39 AM »
Basically, many electrical/electronics components in cars are powered from both alternator and battery. Usually, a new fresh battery will see improvement in driving performance and which is why my UTR Power Charger Evo Series helps a lot in boosting up battery power in your car...  :yehyeh:
