Author Topic: Will after-market HID damage original cover/ holder ???  (Read 5024 times)
« on: August 02, 2011, 10:47:51 PM »
Wil fitting after-market HID burnt e reflector, cover or bulb holder? Understand tat hid generate high heat. I m thinking of changing my fog light to hid but worry it wil damage them. Can any1 advice me? Thks alo
Offline kt
  • Car Color: Amethyst Grey
Re: Will after-market HID damage original cover/ holder ???
« Reply #1 on: August 03, 2011, 02:53:06 PM »
Shdn't be a prob. My ride's previous owner installed HID on the front and fog lights, and I have been driving the car for close to a year  and nothing happened so far.
« Reply #2 on: August 03, 2011, 08:51:53 PM »
So u r stil using hid? Do u find ur lamp cover become blur or turn whitish?i saw sm car having thid problem wif hid installed. So quite wori.
Offline kenniboye
« Reply #3 on: August 04, 2011, 02:13:57 PM »
I installed HIDs for about a year. Reflectors slightly 'burnt'/blur near area where the light reflects from above where the bulb located. As for the headlight housing it remains as clear as before installing the HIDs.
Cheers
« Reply #4 on: August 04, 2011, 04:59:16 PM »
Cheers
Hi!
Thanks for your reply. How about fog light? the bulb is very near to the cover and the space is very small. So i very the heat build up tremendously and damage it.  :confused1: will it?
Offline kt
« Reply #5 on: August 12, 2011, 02:42:36 PM »
So far my ride's lamp cover ok leh. But I just changed back to yellow bulbs coz one of the headlights HID ballast has blown and about to send my car for inspection so I changed the headlights plus fog lights back to yellow
« Reply #6 on: August 13, 2011, 02:07:59 PM »
my HID no problem also.. being using it for 1yr +.
good to have it .. but abit troublesome when going for inspection>> need to change bulb
« Reply #7 on: December 22, 2011, 09:55:46 AM »
Cheers
just realised that the reflector having burnt/ blur marking when i sent to workshop to repair water sippage into headlight. this burnt mark will affect the light throw pattern. the light beam seem not so focus. When first installed, still can see \__ \__. now cant see liao.
my bro oso using HID but without this issue. No burnt mark on his reflector. the color temperature (6000K, 8000K) anything to do with the temperatue of the beam (eg 6000k is hotter, 8000k is cooler)?
Thanks.
Offline kenniboye
« Reply #8 on: January 04, 2012, 06:11:32 PM »
Thanks.
Dun think there is a difference between 6000k and 8000k in terms of temperature - degrees C. Most likely the position of the bulb. My reflectors got slightly burnt after using HIDs for a year. Now changed to back to normal bulb. Still have got the \__ \__. But when using HIDs, no matter how i adjust, only left side got \__.
