Author Topic: Radiator fan not working...  (Read 4538 times)
Offline chrisgio
  • Car Color: Warm silver
« on: August 30, 2011, 09:51:31 PM »
My engine temp turn red and found out the radiator fan not turning? It cost about $400 to change at TC...anyone knows how much to change at outside workshop?
Offline ooi_eddie
  • Car Color: White
Re: Radiator fan not working...
« Reply #1 on: August 31, 2011, 12:05:20 AM »
Have you check the relay? The switch that automatic turn on the fan when hot. Maybe this is the culprit.
Offline david1881
« Reply #2 on: August 31, 2011, 11:49:14 AM »
I had the same problem when new.  I think the high speed fan did not turn on, will over temp if encounter long jam.  Repair cost was free due to warranty.
Like eddie mentioned, it might be just the relay or wiring fault.  If yes the cost should be minimal.
« Reply #3 on: August 31, 2011, 10:31:17 PM »
your radiator fan is faulty liao
Offline fessm
    • Shopping for ladies
  • Car Color: Red
« Reply #4 on: September 12, 2011, 11:19:17 AM »
omg, $400 bucks for radiator fan?  :ohmy:
Now then I noticed that our car dont have temp meter, wahahaha..
Wouldn't it be a little too late to realize/rectify when the temp light is up?
Offline cutelmo
  • Car Color: AMETHYST GRAY
« Reply #5 on: October 28, 2011, 11:11:01 PM »
Could be the cause of poor connection ( the connector got burnt).
* :confused1:Not sure is it the fan located on the very first line in the car bonnet.
That's what happen to mine when the WS engineer show it to me.
« Reply #6 on: October 29, 2011, 06:38:36 PM »
ho do we know if the fan not working? only when the temperature indicator turns red?
Offline cutelmo
« Reply #7 on: October 29, 2011, 09:30:44 PM »
On the air-con and open the bonnet, than see if the fan is spinning.  :confused1:
« Reply #8 on: October 29, 2011, 09:40:47 PM »
there are 2 speed for latio fan motor,some times the first speed is faulty.
