Author Topic: Car sometimes can sometimes cannot start  (Read 10110 times)
Offline freak
« on: September 23, 2011, 08:09:15 AM »
Hi guys
Have u faced this kind of problem? My car can crank and engine starts for half a second then die. What could be the problem?
Spark plugs?
Any kind of relay?
Batt was just changed last month.
Mileage is now 105k.
Thx for the help.
Re: Car sometimes can sometimes cannot start
« Reply #1 on: September 23, 2011, 09:17:29 AM »
ignition coil faulty? Spark plug misfire? or Trottle body is too dirty.. no choice, sent to workshop to get answer.
Offline m_k_tang
« Reply #2 on: September 23, 2011, 10:56:50 AM »
Hi guys
Spark plugs?
Any kind of relay?
Thx for the help.
Are you able to drive your car eventually even though you cranked the engine and die off? Have you check whether battery connections are tightened? When was your last change of spark plugs? The problem can come from many things such as fuel pump, fuel filter, MAF (air flow sensor) and air filter, ignition coil/s, spark plugs, etc etc.... Any engine check light? What is the battery condition or CCA (cold cranking amperes/power) when you bought it? Did the battery shop show you any reading to show that the battery is fresh and/or in new condition? Otherwise, you have to go to workshop especially those shops with diagnostic equipment to check your car.
Btw, you can still start your car with dirty throttle body but just that the RPM especially idling is not very stable as carbon and dirt may have clogged the butterfly valve...
Offline freak
« Reply #3 on: September 23, 2011, 01:16:42 PM »
Hi
Yes manage to get it started after a few tries interval of 2-3mins. I have not changed the plugs, will do so asap together with my servicing.
Do you have any recommended workshop with all this diagnostic stuff?
Its been happening since last week, sometimes 2 days once, sometimes 3 days once.
This morning i manage to go to Point A (park and off engine). Then from Point A to B (park and off engine). From Point B that is where it start for half a second then dies off. Eventually manage to start it again.
Offline m_k_tang
« Reply #4 on: September 23, 2011, 02:11:36 PM »
Hi
The immediate thing you can do right now is to check your battery terminals for loose connection. As for those workshops with diagnostic equipment, my company has tied up with 4 of these workshops throughout Singapore to serve our 8000+ members/customers. Do let me know which area you are staying or working so that I can recommend you to the nearest workshop (in Autobay, Toh Guan, Ubi or Woodlands).
Offline freak
« Reply #5 on: September 23, 2011, 02:50:44 PM »
Can you let me know the address for Toh Guan and Woodlands?
What time does the Woodlands shop close on weekdays? Might just go today for change of plugs.
Who to look for?
Offline m_k_tang
« Reply #6 on: September 23, 2011, 05:25:28 PM »
Who to look for?
I will recommend you to Woodlands workshop. The workshop boss is Billy. Just mentioned Johnny recommends you to him. I will PM you his workshop address later
« Reply #7 on: October 05, 2011, 04:51:12 PM »
Can you please PM me the workshop address too.  Thanks
Offline m_k_tang
« Reply #8 on: October 05, 2011, 10:13:15 PM »
Hi bro,
Check your PM on the workshop address. Feel free to get back to me again if you have further enquiry.
Offline spyder_696
« Reply #9 on: October 09, 2011, 11:42:44 AM »
Hi guys
Spark plugs?
Any kind of relay?
Thx for the help.
i got now the same problem as you...
sianz.. did u manage to solve the problem...
hope u can kindly advise..
before my engine sometime can start, sometime cannot start..
the engine check light did light up 2 times in between 2 to 3 month period ago...
Offline spyder_696
« Reply #10 on: October 09, 2011, 11:46:20 AM »
my car service by autosaver, the got run diagnostic and says everything okay.. that was 5k mileage ago.
now is 55k there about mileage..
battery is good condition, only maybe 1 year old.. engine cannot start is not cold state.. is hot state after maybe 50km and resting 10min... it cannot start.. only after 10-15 cranks then it starts..
wow, u state so many things must check ah.. u suggest tan chong or autosaver can do same job..
another month short of being 4 yrs old... at 55k mileage...
Offline spyder_696
« Reply #11 on: October 09, 2011, 11:49:48 AM »
which workshop, any suggestion..
Offline freak
« Reply #12 on: October 18, 2011, 09:55:07 AM »
i didnt do anything or go any workshop as yet, my car suddenly decide to respond back as per normal. touch wood. now no more 'cannot start' syndrome as yet. but i still wanna change my spark plugs as reach 105k mileage liao. and some 'knocking' can be heard already.
any workshop recommendation and price for plugs change?
thanks
Offline trex101
« Reply #13 on: October 25, 2011, 04:46:42 PM »
thanks
Denso FXE20HE11 cost $110/set, labour for plugs change various with workshop but cheapest would be freelance mechanic, around $30.
Your One Stop Oil Shop
www.mxtradings.com
Redline, Amsoil, Pennzoil, Schaeffer
Royal Purple, Mobil 1
NGK & Denso iridium
Duragloss Products
Osram Nightbreaker & Philips X-treme Vision
