Author Topic: Check Engine Light-CEL / Malfunction Indicator Light - MIL  (Read 11637 times)
Offline Latio_33
  • Car Color: Grey
« on: November 01, 2011, 04:40:56 PM »
Hi Guys,
Recently my latio have this CEL/MIL lighted up and the slow was like 1.5K.  I switch off and on again couple of times and once the light is off, my slow RPM return back to normal around 750-800.
This happens on/off not frequent but it does happen.
Have went to AutoSaver and TC for a dianostic test but they seems cannot find the fault and claim it is the throttle body and the accelerator postion sensor.  Ask why is this so, AS cannot give an answer whereas TC mentioned it might be the K&N filter I'm using.
Solution to this, change the throttle body plus the sensor and use back the original filter.
Any Bros/Sis here could advise where can I get another opinion?  Autoaid or any workshop??
thanks in advance
Regards
Offline Mr_Brasso
Re: Check Engine Light-CEL / Malfunction Indicator Light - MIL
« Reply #1 on: November 02, 2011, 10:16:11 PM »
Did you install those electronic throttle controller?
I got the same problem after using it for 6 months.
Went to Autosaver Kaki Bukit and they diagnosed the issue to be the controller affecting the circuitry.
I removed it and no longer have this problem.
Hope this helps...
« Reply #2 on: November 03, 2011, 07:14:53 AM »
didn't know throttle controller will cause this problem, may I know what brand is yours?
mine is shadow brand and sometimes i do worry about its reliability as compared to the more established pivot brand.
Offline Latio_33
  • Car Color: Grey
« Reply #3 on: November 03, 2011, 05:40:13 PM »
Hope this helps...
Nope..nothing..everything is stock except my K&N filter and front Struct..not even ICE
Anything else that I should check upon.  Having my K&N for 2 mths till now than the CEL pop up on and off.  After TC so call reset it, have been monitoring..so far so good.  TC mentioned that it is the Throttle chamber error and may due to I use K&N filter which 1st time I ever heard of this cos all my previous car been using K&N
Btw, which autosaver you went and who did you look for?  Able to share contact?
« Reply #4 on: November 03, 2011, 10:54:22 PM »
I think quite a few members are using KNN  and everything seems to be alright. I've been on it for the last 80+K.
Offline Latio_33
  • Car Color: Grey
« Reply #5 on: November 04, 2011, 09:11:16 AM »
totally agree...so how could be the K&N??  Furthermone it is new not as if I need oiling to be done
Offline m_k_tang
« Reply #6 on: November 04, 2011, 11:57:53 AM »
Nowadays, good products depend on quality and control. If you go to some forums, there are complains that their brand new KNN filter clogged their MAF with too much oil and causes engine CEL on & off frequently. The best is to take out filter and put on newspaper and let it dip dry. I guess there is no such thing as 100% guarantee perfect nowadays.
Offline Latio_33
  • Car Color: Grey
« Reply #7 on: November 04, 2011, 01:03:18 PM »
Hmm..that makes sense..maybe you are right..let me take it out over this weekend.
Offline spyder_696
« Reply #8 on: December 01, 2011, 01:52:35 PM »
Hi Guys,
thanks in advance
Regards
i got the same problem as you for at least 5-6 times over the last 2-3 months period...
my servicing is due soon, and i will check with autosaver comment (defu branch)...
i did my last 2 service with them... this problem didnt surface before my last service with them...
my car is 100 percent stock beside a volt meter..
normally i need to restart 3-5 times...
but i ever experience restart more than 10 times then okay...
worrying sia... 4 yrs old liao...
with coe price now.. it must last me 10 yrs lei...
Offline tan1688
« Reply #9 on: December 17, 2011, 01:34:02 PM »
hello bro_latio33 and spyder_696,
i got the same problem as you described as well, mine is 3.5yrs old latio 4AT,
all stock original parts no modifications.
1) When start to use vehicle at morning, ignition on, cranking sound is there
but then the CEL check engine light will turn on after a while, then engine
RPM drops to 700rpm. Stepping on the accelerator pedal the engine RPM
cannot go up. Change to gear D and step on accelerator pedal the car
move a bit only ,, no power ?
Normally is when ignition on, cranking, the engine would start at 1600RPM
before drop to 1200RPM and change gear to D drive drop to 900rpm step
on accelerator pedal and got power to drive.
Then re-try ignition on a few times 5 times before CEL goes off and the normal
engine RPM at 1000rpm.
2) Yesterday while starting to drive off vehicle after 5minutes the CEL went up
and sudden drop of engine rpm from 1300rpm to 700rpm, though i step on the
pedal still the engine RPM does not go up .. have to restart a few times
then is back to normal.
3) happens already quite often in a couple of months.
I suspect is the throttle body motor dirty or got stuck and cannot flip open ?
thus i took out the stock nissan air filter still red color means clean,
but i still clean a bit using degreaser, blow dry and under sun till dry
and put back.
Could you please update me if you have any findings ?
i brought to mechanic yesterday but he said the CEL is intermittent, he could
only check if the CEL light is on, then i tried a few times still no CEL ..  :confused1:
Intermittent problem.
« Last Edit: December 17, 2011, 01:55:20 PM by tan1688 »
Offline tan1688
« Reply #10 on: February 20, 2012, 09:34:13 PM »
Started ignition and Check Engine Lamp comes on and off
intermittently  :mad: when the CEL is there, vehicle goes
to limp mode and no response after stepping on acclerator,
got to turn off and turn on ignition for 10-20 times before
the CEL is off, then everything works fine.
Went to a mechanic for the Check Engine Lamp issue, diagnose
as P2135 Throttle Valve Position Sensor Malfunction.
The shell mechanic explained the behind the throttle body motor
which detect the flap open and close, ratiometric resistive sensor
may have spoilt.  :ohmy:
Anybody got similar experience any comments ?
Offline spyder_696
« Reply #11 on: March 16, 2012, 10:27:33 PM »
today my engine check light came out when i was nego a zebra crossing type of junction..
engine brake the whole car, i quickly switch on hazard light and restart the car to get it back to normal ops.
the autosaver guys says must change many things that will cost up to 600 bucks...
i didnt do it.. that was around 3000km ago...
worrying sia... dont knw the cause..
some more need to go kl often..
anyone got any more updates...
Offline tan1688
« Reply #12 on: April 07, 2012, 12:20:59 PM »
i got update went to Tan chong Ubi, get checked by OBDII diagnosis
tool, service advisor says the throttle body got to change.
Thus have changed throttle body and the CEL does not come up
anymore. From my last post the throttle valve sensor is behind
the throttle body, they got to change the whole throttle body
cannot just fix the throttle valve sensor.
Total damage : Change throttle body $216.99 sgd + OBDII diagnosis $69.55 = $286.54  :(
heart pain.
After changing for 1month, CEL does not come up anymore.
Since it is intermittent problem when i went during 1st service they
said no problem the mechanic did not do anything just OBDII
diagnosis charge me 69.55.
When i collect car, i switched on and off engine for 20 times,
drive around UBI for 5 times, each time stopping switch off
and on engine. The CEL still comes up and on limp mode go
back to show service advisor problem not solve...
then the service advisor asked to leave car overnight check
next day again where they inform to change throttle body.
Offline kfymartin
« Reply #13 on: May 08, 2012, 08:53:47 AM »
had the same problem late April this year. when to TC and they said its was the throttle fault and change it with labour for 200sgd exclude Gst. now seems to be working, will need to monitor.
Offline spyder_696
« Reply #14 on: May 17, 2012, 05:07:33 PM »
heart pain.
hi sir, same problem like you.
but i service at bukit timah.
price same like you.
just cannot understand why the spring return throttle valve cannot return.. ha ha..
anyway, your cold start idling rpm = ?
mine is around 1.5k maybe until few km later then will drop to 1k or 900rpm..
