Author Topic: Steering Coupling  (Read 17847 times)
Offline Ryan9413
  • Car Color: Silver
Steering Coupling
« on: November 19, 2011, 02:28:03 PM »
Does anybody knows wats the cost to replace the steering Coupling at TCM or Autosaver?
Re: Steering Coupling
« Reply #1 on: November 19, 2011, 03:15:43 PM »
i never even had this thought i just drove to tcm during servicing n tell them to deal with it its a design defect n not wear n tear. told them to see my record 3 yrs change 4 times regrease twice n u want to charge me for it?
in the end they LL change for me foc
« Reply #2 on: November 19, 2011, 09:20:47 PM »
iirc the cost at TCM is abt $500+
Offline Ryan9413
  • Car Color: Silver
« Reply #3 on: November 20, 2011, 06:43:36 PM »
Wah costly, Is it safe not to change the coupling?  Will it cause further damage?
« Reply #4 on: November 21, 2011, 07:38:03 AM »
maybe you can try outside workshop to get a quote.
mine since changed a few years back during warranty, so far problem never occur again.
to add on, the mechanic at TCM did tell me before that this steering coupling problem will not affect the car performance or safety, just annoyed at the noise.
« Reply #5 on: November 21, 2011, 10:27:40 AM »
Only TCM can do it. Autosavers cannot
« Reply #6 on: November 21, 2011, 11:44:23 AM »
There's no safety issue Just bear with the noise and u don't have to spent a single cent
Can try lubricate it someti
me it might help.
Offline quirky
« Reply #7 on: November 21, 2011, 01:03:11 PM »
Anyone has the problem where the steering wheel will make a of noise and vibrate when going over slightly uneven grounds (eg the slopes with grooves in hdb mscp)?
Offline xman13
  • Gunners
« Reply #8 on: November 22, 2011, 10:32:12 AM »
I have this problem... u need to change the gasket in the front brake assembly .. (brake bracket kit). replace it soon as sometime even dring at high speed the wheels vibrate. it is dangerous. Cost less than $200 with labour.
Offline quirky
« Reply #9 on: November 22, 2011, 07:10:29 PM »
Thanks. TC lubricated the steering joint instead. Didn't solve the problem. Darn.
Which service centre did you go to where they gave you this diagnosis?
Offline tower22
  • Car Color: Red
« Reply #10 on: November 24, 2011, 09:22:19 PM »
This is exactly what im experiencing. i test drive with TC over strips and uneven grounds. That sa told me its normal ..
Offline Ryan9413
  • Car Color: Silver
« Reply #11 on: November 24, 2011, 09:24:54 PM »
Check the cost of changing steering coupling  at AS about 300++ but haven include labour, anyone try change there before?
Offline quirky
« Reply #12 on: November 24, 2011, 10:56:26 PM »
You should let the mechanc take the wheel instead. I let the SA took the wheel, and he proposed lubrication.
Didn't work.
Offline jovially
« Reply #13 on: November 25, 2011, 08:12:27 AM »
Replace at TC. under warranty.
But think it will come back again.
Told the SA, he say need to get a tech to test drive with me, I told him don't need test drive. it is a known issues.
So at the end they change it for me.
« Last Edit: November 25, 2011, 08:15:16 AM by jovially »
Offline 1258
« Reply #14 on: November 28, 2011, 10:13:41 AM »
Yes I did have the same problem this problem must get the TC advisor to try your car @ the bukit timah turf city
MCP then they can hear it, this is wat I did after many many time go back to them & during testing they can't hear it cause of the road condition.
Offline quirky
« Reply #15 on: November 28, 2011, 02:26:10 PM »
What did they do to fix it? Change the steering coupling?
Offline xman13
  • Gunners
« Reply #16 on: November 30, 2011, 01:29:13 PM »
I did at auto saver. they clean the brake coupling(i think) and change the gasket.
Offline 1258
« Reply #17 on: December 01, 2011, 02:54:23 PM »
This rounnd not the couping is the power streeling motor & 1 more part just bellow the wheel. Try to
go buck & test drive with them if not it will be too costly after warrenty.
Offline 1258
« Reply #18 on: December 01, 2011, 04:34:45 PM »
I have just found out the name of the parts it is strg module & strg motor, the mentioned parts tooks 4 mth
to deliver from Japan.
Offline edwardtkh
« Reply #19 on: December 01, 2011, 07:46:17 PM »
Hi bro, How much for these parts?
