Author Topic: air con  (Read 13735 times)
Re: air con
« Reply #20 on: March 07, 2012, 04:31:49 PM »
Thanks boey  :smile:
Offline ahjie
  • Car Color: blue
Re: air con
« Reply #21 on: March 07, 2012, 06:23:50 PM »
Hi bro's,
   Few months ago i'm also had the same problem of a/c not cold at all especially, during hot weather blow out hot air instead cold air. Went many place to checked and alot of comments from different mechanic's. End up my friends told me to seek Air-con specialists at yew tee area. They diagnosed that my compressor clutch spoilt do a repaired. Magnetic coil leak, replaced a new set. plus top up AC gas. No GST been add. total i spend $440. No bad service. :smile:
I paid $235.40 ($220+GST) to replace my faulty magnetic clutch coil including compressor oil, vacuum and recharge gas. But I'm not sure whether they use a brand new or reconditioned set. Perhaps, I'll try to check whether I can see the replaced part clearly from the bonnet on a bright day. Otherwise I'll call to ask them.
Re: air con
« Reply #22 on: March 07, 2012, 09:53:58 PM »
Kelvin, the symptoms i encounter is aircon suddenly not cold, only feel the fan. So off the aircon and wait 2-3 mins, turn on and it gets cold again. Sometimes gotta wait longer to restart aircon. I highlighted this problem when i sent my car to tc for servicing. After servicing, they told me topped up ac gas and vaccumed the ac and solved the problem. The ac behaved normal for next two days.
Three days later, problem come back again and i went back to tc. After checking (suspect they din even check the first time), service adviser told me cooling coil leak and compressor jammed. Quoted me $1500 inclusive labor to change both. Highly suspicious about their assessment so i told them i wanna get a second opinion. Before i left, they wanted to charge me $79 for another ac gas top up. Angry, i refused to pay and reasoned with the service advisor. Never solve my problem still wanna charge me extra $$ by pumping gas into a leaking coil!?
Ahjie, thanks for ur pm.
hi bro,in the first place,if ur compressor jammed ur a/c will not be working now even if they top up gas.secondly if ur coil leak why they just vaccumed ur sys and top up gas for the first visit?agent should know the problem better then others.now they wanna earn money so say that all things must change.PM me if u wanna me to check for u. ;D
Offline boey
Re: air con
« Reply #23 on: March 08, 2012, 09:22:24 AM »
Bro ahjie,
Is it the A/C specialist do it? That is cheap. Where is the W/S? can share?
Offline ahjie
  • Car Color: blue
Re: air con
« Reply #24 on: March 08, 2012, 11:39:57 AM »
Bro ahjie,
I did the repair at a car aircon ws in Ubi. I've sent you a PM.
For replacement of aircon compressor, the cheapest quote I managed to get was from another car aircon ws in woodlands. They quoted $600 net for a brand new original set with 3 mths warranty. Other servicing ws quoted me around $680 for original set with 6 mths warranty & $380 for OEM set with 3 mths warranty.
Offline boey
Re: air con
« Reply #25 on: March 08, 2012, 02:43:56 PM »
bro,
  Actually all the warranty not really true. We are not the mechanic we don't know what is the actual problem. When the moment spoilt and you send in they will tell you another stories of part spoilt or even more problem that make you must change it.  :confused1:
Offline ahjie
  • Car Color: blue
Re: air con
« Reply #26 on: March 08, 2012, 07:52:18 PM »
Ya, that's why I opted for the cheapest repair option instead of replacing the whole compressor. After all, I'm not mechanical savvy so will not really know if the ws want to smoke me.
Offline Blim
Re: air con
« Reply #27 on: March 27, 2012, 12:09:18 PM »
hi bro, my aircon also got similar problem as boey and it so frustrated as to manually turn off the a/c switch to "con" the car in order to get restart the aircon.
Can anyone recommend any cheap and reliable ws to solve this problem.
Thanks in advance ;D ;D
Re: air con
« Reply #28 on: March 31, 2012, 11:48:03 PM »
hi bro that's the compressor giving way liao.
