Author Topic: Sound at only initial moving off  (Read 3223 times)
Offline wooks
« on: April 18, 2012, 07:21:56 AM »
I have a "thud" sound front engine at the initial moving off at 20km & 40km.  After that, no more of this, but whenever a new start on the engine, it will be heard again during each time and only the initial move off.  Anyone encounter & solution to it?
Re: Sound at only initial moving off
« Reply #1 on: April 18, 2012, 07:36:14 AM »
is it the sound of the aircon compressor kicking in?
« Reply #2 on: April 18, 2012, 10:47:17 AM »
This should be the 'ABS' check sound when you travel more than 20-30km/hr........  It get obvious as the car grows older...
Offline wooks
« Reply #3 on: April 18, 2012, 11:07:03 AM »
It's not from air con.  So if ABS check, how to eliminate or reduce it?  Will replacement or tighten the belt helps?
