Author Topic: Adjusting headlight height  (Read 4359 times)
Offline weesern
  • Car Color: Silver
« on: May 29, 2012, 10:01:16 PM »
how do we adjust the height of the headlights?
Re: Adjusting headlight height
« Reply #1 on: May 29, 2012, 10:07:09 PM »
behind the headlamp there are screw to adjust.
Offline weesern
  • Car Color: Silver
« Reply #2 on: May 29, 2012, 11:58:23 PM »
Found it!! thanks
Offline weesern
  • Car Color: Silver
« Reply #3 on: June 09, 2013, 05:33:45 PM »
is the two adjusting screw? one for up and down, the other is for left and right??
the screw for up and down seems easy to adjust and the movement of the headlight is very obvious.
Tried adjusting the other screw but cannot tell the difference... Whats the best way to adjust them left and right?
« Reply #4 on: June 09, 2013, 08:56:50 PM »
left and right adjustment screws are on the side, there is a guide for your screw driver, needs to be long screw drivers.
Offline weesern
  • Car Color: Silver
« Reply #5 on: June 10, 2013, 02:53:50 PM »
tried turning it but the light not moving, or maybe it is but movement not as much as the up and down... so not sure if it ismoving at all
« Reply #6 on: June 11, 2013, 10:14:47 AM »
Bear in mind that your distance to the wall that you're projecting your headlights to is not quite as far as it would in real driving condition so on to 2 degrees of change might be adequate in driving conditions and it doesn't seem much on the wall.
Offline dthh
  • Car Color: RED
« Reply #7 on: June 12, 2013, 10:13:23 AM »
Can anyone post a photo on the left and right screw? I can't fine them.
I only find up/down screw....
Many thanks.. :smile: :smile:
