Author Topic: Car veers left even after tire rotation and wheel alignment  (Read 4790 times)
Offline snuffablescoopy
  • Car Color: Champagne Gold
All, my ride was previously ok, able to travel straight with my hands off the steering.
But for the last ~ 2mths, it started to veer quite badly to the left (maybe 10-15degrees immediately after letting go of steering). Went Autobacs (Loyang) twice to do wheel alignment, it got better but still veers left (mayb 5-10degrees 3secs after letting go of steering). The mechanic told me that it's normal since no road is perfectly straight, but i don't recall my ride having such problems in the past 1yr.
I thought it was due to tyre pressure and tyre rotation, so i got my rims changed, tyres rotated and tyre valves changed. Still the same problem.
I didn't hit any kerbs, no accidents before.
Any bros out there can advise what could be the source of the problem?
Thanks in advance.
Re: Car veers left even after tire rotation and wheel alignment
« Reply #1 on: June 12, 2012, 04:24:11 PM »
have you try kenny alignment at amk autopoint level 4 same as riverview auto?
he might be able to serve your problem.
« Reply #2 on: June 13, 2012, 10:00:55 AM »
Look for Kenny or Kelvin?
« Reply #3 on: June 13, 2012, 02:40:21 PM »
Kenny alignment on level 4, he specialise in alignment.
« Reply #4 on: June 15, 2012, 01:35:41 PM »
Try changin to adjustable camber kit, dats wat i did & it solved my misalign issue.
« Reply #5 on: June 18, 2012, 04:23:44 PM »
pardon me...but what is a camber kit?
Anyway, went to Bro Kelvin and he swapped the front left and right tires and it solved  the problem  :yehyeh:
« Reply #6 on: June 19, 2012, 07:14:51 AM »
interesting, is your tyres directional tyres?
« Reply #7 on: June 19, 2012, 10:18:56 AM »
Not sure abt that...but i'm using Goodyear efficientgrip
« Reply #8 on: June 19, 2012, 02:06:30 PM »
its ok bro, just don't know why swapping tyres from left to right and vice versa will solve your alignment problems  :confused1:
« Reply #9 on: June 19, 2012, 06:38:01 PM »
bro snuffablescoopy's tyre is not rotational tyre,that why can cross from left to right.
