Author Topic: anyone replaced coolant with other brand instead of  (Read 4716 times)
Offline dm
  • Car Color: Clear
« on: June 21, 2012, 10:22:39 PM »
what was recommended in the manual, nissan long life coolant? thinking of trying engine ice but it is propylene based and not sure if it's suitable for our car. :unsure:
Offline dm
  • Car Color: Clear
Re: anyone replaced coolant with other brand instead of
« Reply #1 on: July 01, 2012, 06:19:37 AM »
nobody?
Offline RB20DET
  • Car Color: White
« Reply #2 on: July 03, 2012, 08:29:50 AM »
Just use back Nissan .... or any coolant with lower pH. Else your tank will rust ... ;D
Offline dm
  • Car Color: Clear
« Reply #3 on: July 06, 2012, 12:17:24 PM »
 :confused1: what tank will rust? the coolant reservoir is plastic. ethylene glycol coolant pH is ~7 as it is mixed primarily with distilled water.
« Reply #4 on: July 07, 2012, 01:44:53 PM »
metal la
Offline dm
  • Car Color: Clear
« Reply #5 on: July 10, 2012, 10:54:16 PM »
there is a metal coolant tank in our car?  :confused1:
« Reply #6 on: July 11, 2012, 09:13:57 AM »
the coolant reservoir tank is plastic but the fuild will contact with many metal parts in the process of cooling. Your radiator can not be plastic correct?
« Reply #7 on: July 11, 2012, 09:12:20 PM »
pls don't TOYOTA long life coolant to replace ur coolant,it'll damaged ur radiator. :nonod:
Offline DARKSCALE
« Reply #8 on: July 17, 2012, 12:37:02 AM »
using redline water wetter. so far so good le.
just replace every 2 year and forget about it.
« Reply #9 on: July 17, 2012, 08:42:11 AM »
yeah so far had use engine ice & water wetter for both bike n car, no side effect or any corrode of radiator.
