Author Topic: Metal sound when accelerating  (Read 32110 times)
Offline skullcap
  • Car Color: Amethyst Grey
Re: Metal sound when accelerating
« Reply #20 on: August 13, 2012, 12:13:11 AM »
Yup. I think its the same sound. Btw, how old is yr car? What have you tried so far in trying to resolve this? Has yr prob been resolved?
My car is 5yrs ord. Can't reali find e source yet. Hv 2 keep looking. Keep us updated if u manage 2 rectified it. I'll do e same also.
Offline ecys
« Reply #21 on: August 13, 2012, 12:39:38 PM »
might be the air filter box is loose, which happened for my case, just check whether the box is loose anot.
Offline Voltage
« Reply #22 on: August 26, 2012, 01:56:41 PM »
i always hear this metal coming from the left of the car when seated in the driver seat when i start and move off.. one metal knock at 10kmph then 5metal knocking sounds when at 30kmph... its been bugging me... so its the ABS testing sound???
as for the rattling when accelerating and can be heard clearly in multi storey when your car is surrounded by walls, i had that before also...
confirm its engine knocking due low octane fuel used. try higher octane fuel.... really remove the knocking.
Offline silver06
« Reply #23 on: August 27, 2012, 11:23:52 AM »
I also encountered the same problem, went down to kelvin's workshop to check.
Was told is common among lation.... Try higher octane fuel, the noise reduce.. But sometimes still can hear..
 :unsure:
Offline skullcap
« Reply #24 on: August 30, 2012, 04:49:15 PM »
Bro, I thk my sound gone ord. Went to Kelvin's plc to change some things n clean throttle body. After doing that he plug in the OBD device to reset back the engine settings n now engine is more responsive, smooth, FC improved n torque increased. Like what Jazz said engine ping could be the cause(guessing only) n I'm still using 95oct petrol. :thumbsup: :thumbsup:
Offline lhhao
« Reply #25 on: August 31, 2012, 12:15:21 AM »
Bro, care to share the things that you have changed?   ;D
Offline skullcap
« Reply #26 on: August 31, 2012, 11:27:47 PM »
I changed air n aircon filter, plugs n CVT oil. Discovered tat everything very dirty ord. My car was pre-owned, maybe previous owner didn't replace those. But i think the only significant change tat matters could b the reseting of the engine n I'm only guessing. Still curious abt the sound tho...hope dis helps :smile: :smile:
Offline skullcap
« Reply #27 on: December 11, 2012, 05:25:04 PM »
Bro,
still having the metal sound?
Offline maverick_2007
« Reply #28 on: December 28, 2012, 03:00:55 PM »
I'm having the sound too, been there for past 2 yrs or so. Noticed that when I first start off the car, its fine, the sound usually starts after then engine has been running for a while. To mee this definitely feels like engine ping.
I think what bro Jazz said is correct, "cause by bad ratio mixture of fuel and air which indirectly incur bad combustion", feels like the car is running in a higher gear than it should for the current speed of the car, which is probably why it happens more at lower speeds.
So any other feedback on how to get rid of this sound....  thanks for all the inputs.
« Reply #29 on: December 29, 2012, 01:26:12 PM »
You may want to do a TB cleaning and re-mapping or tuning ? See if this helps.  ;)
« Reply #30 on: February 27, 2013, 11:52:41 AM »
Bro, whats TB cleaning?
« Reply #31 on: February 27, 2013, 06:15:31 PM »
TB meaning throttle body  ;D
Offline ng.melvin
  • Car Color: black
« Reply #32 on: April 23, 2013, 05:43:48 PM »
Where is KElvin's place?
sms me at 94554903....
mine is exactly the same problem... 1 knock at the start around 10km/hr then 5knocks at 30-40km/hr only at startup...
from stationary at traffic light no problem.....
 :confused1:
« Reply #33 on: April 24, 2013, 10:40:57 AM »
That is the ABS sound.  Very normal.  Always kick in at startup when you reach 30Km/hr.  This is to inform you that ABS is still working.
 :confused1:
Offline ng.melvin
  • Car Color: black
« Reply #34 on: April 24, 2013, 04:18:11 PM »
anyway to reduce the sound? its getting really loud recently...
« Reply #35 on: April 26, 2013, 08:44:36 PM »
No,unless u change new ABS actuator.
Offline blurrynavy
« Reply #36 on: June 03, 2013, 09:28:28 PM »
I'm also experiencing this same problem for the noise..is it safe not to change the actuator? Oredi 7 year car...hmm...
