Author Topic: brake/ tail light bulb size?  (Read 8557 times)
Offline PTC77
  • Nismo LaTIo
« on: November 19, 2012, 08:44:56 AM »
Can help confirm if t20 is the correct size for brake light?
Re: brake/ tail light bulb size?
« Reply #1 on: November 19, 2012, 05:38:59 PM »
i think is P21/5W... you better remove the faulty bulb and double confirm
Offline limcc
  • Car Color: Silver
« Reply #2 on: November 20, 2012, 10:07:39 PM »
1157
Offline rongshu
« Reply #3 on: September 11, 2018, 03:22:29 PM »
From service manual
Front combination lampWattage
High beam60W
Low beam55W
Turn signal/Park lamp28/8W
Side marker lamp5W
Rear combination lampWattage
Stop/Tail lamp21/5W
Turn signal lamp21W
License plate lamp5W
High-mounted stop lamp16W
Offline rongshu
« Reply #4 on: December 31, 2018, 08:46:15 AM »
Recently just changed the tail brake bulb by myself. Super easy to DIY.
1. Remove the clips from the liner. The liner is soft and can be bent so I just removed 3 clips. Use a flat head screw driver to pry the clip.
2. Bend the liner and you will see the tail light connectors. There is no need to remove the whole assembly. You can actually remove the individual bulb connects by twisting it.
3. Twist the bulb out from the socket. And put in the new bulb.
The rear brake bulb is P21/5W. Socket type is 1157. I bought from Autobacs @5.9 which is expensive. You should be able to find cheaper online or from other retailers.
« Last Edit: December 31, 2018, 10:02:39 AM by rongshu »
