Author Topic: Knocking Sound When Car Stopping  (Read 5877 times)
Offline jovially
« on: December 27, 2012, 07:44:36 PM »
Is it normal when stopping the car, I can feel a "pop" sound when pressing on the break.
Esp if I press it hard.
« Last Edit: December 29, 2012, 10:52:54 AM by jovially »
Offline jovially
Re: "Pop" sound
« Reply #1 on: December 28, 2012, 10:11:52 AM »
No sure should I call it "knocking noise".
Any expert here care to advise is this normal?
Only encounter recently.
Offline valles
  • Car Color: White
Re: "Pop" sound
« Reply #2 on: December 28, 2012, 11:11:34 AM »
Not sure how hard is your "hard".
If you are referring to last minute jam brake then it should be normal. However if everytime you step on brakes and you hear popping sound then better to have it checked.
Offline jovially
Re: "Pop" sound
« Reply #3 on: December 28, 2012, 11:30:00 AM »
Thanks for your reply.
When stopping the car, if I step the breaks slowly till the car fully stopped, the last step so call hard step, can feel a "popping" sound. is this normal?
« Last Edit: December 29, 2012, 10:55:08 AM by jovially »
Offline valles
  • Car Color: White
Re: Knocking Sound When Car Stopping
« Reply #4 on: December 29, 2012, 12:29:55 PM »
Not sure if I understand correctly....
unless its the slight slipping of the brakes then I do hear the popping sound... its akin to the brakes and the caliper are at biting point.... that is my tender tapping of the brakes... normally stationary at traffic lights while waiting for green....
However if you are referring to gentle brakes while your car is moving and yet you hear popping sound then better to have it checked out for safety reason.
Offline jovially
« Reply #5 on: December 29, 2012, 06:48:55 PM »
Thanks. The popping sound happen when stopping the car. Gentle brakes till completely stop the car, during this last step - completely stop and fully pressed on the brake, the popping or knocking sound happen.
So, this is normal?
Offline valles
  • Car Color: White
« Reply #6 on: December 30, 2012, 09:18:42 AM »
So, this is normal?
Perhaps you can try gentle braking and when your car is almost stationary... step harder on the brake and see if the popping sound still occurs. It does happen at times to my car due to the biting point of the brakes and the caliper. It's like the brake is almost holding on tight to the caliper and yet letting it slip hence that results in the popping or knocking sound and its pretty audile even with car audio on.
And this is pretty much more obvious is its after rain or car wash when the caliper is corroded. Try it out and if you are still worried then better have it checked cos brake is a crucial component hence better not risk it.
Offline jovially
« Reply #7 on: December 30, 2012, 09:41:24 AM »
Thanks. Yes, this is what happening to me.
So is the caliper and the brakes.
Not sure how much is your repair cost.
Think have to go back Nissan or riverview to have it repair.
« Last Edit: December 30, 2012, 01:00:29 PM by jovially »
Offline valles
  • Car Color: White
« Reply #8 on: December 31, 2012, 01:02:11 PM »
If what I described is what you are experiencing then it perfectly normal. Dun waste money on diagnosis. Go kelvin bro workshop for your next servicing and he will help you do a thorough check.
Offline jovially
« Reply #9 on: December 31, 2012, 01:38:10 PM »
Thanks brother.
Ok, since it is normal, will wait till next servicing.
