Author Topic: Water pump leakage  (Read 4034 times)
Offline Panerex
  • Car Color: red
Water pump leakage
« on: January 05, 2013, 11:06:51 AM »
Slight leakage of water pump.
Tan Chong asks me to monitor.  How if I want to change, it will cost $300 at tan Chong.
Any bro got cheaper lobang to do at outside workshops?
Offline ckmckm
Re: Water pump leakage
« Reply #1 on: January 06, 2013, 05:55:02 AM »
bro, I think you ask Kelvin to check for you. Sometime it is the way they work, trying to earn more money from you. actually, there's nothing wrong with the water pump and it can still work for another couple of years.
Offline ckmckm
« Reply #2 on: January 06, 2013, 05:56:25 AM »
I don't trust Tan Chong anymore after my aircon incident
Offline dthh
  • Car Color: RED
« Reply #3 on: January 06, 2013, 09:24:02 AM »
My suggestion :smile:
Just see if you need to top up water every week for more than 250ml, then better get it check ASAP.
Sometime may not be the pump but it's connection.
Offline wooks
« Reply #4 on: January 06, 2013, 06:39:15 PM »
Check your radiator.  After moving, park ur car with ur engine on, open your bonnet and check your radiator surrounding for any leaking.
Offline Panerex
  • Car Color: red
« Reply #5 on: January 06, 2013, 07:45:04 PM »
Thanks for all the kind replies.
By opening up the bonnet and check the radiator, is it to see the coolant is leaking from the radiator box?
Also, if the problem is serious enough, will there be any indication or warning on the dashboard?
Offline edwardtkh
« Reply #6 on: February 02, 2013, 06:36:36 PM »
If coolant leak, easy to spot because coolant itself is luminous green. I just changed my radiator assembly after it cracked and burst.. the engine compartment is spilled with the green coolant. Prior to that, one of the tell tale sifn is that the coolant level alwaysdropped below the minmimum mark..
Offline wooks
« Reply #7 on: February 02, 2013, 09:22:15 PM »
Don't drag ur car, it will burst the leak if there is a weak point.  Quickly, check it up.
