Author Topic: Dashboard error  (Read 5353 times)
Offline alvinlee
  • Car Color: black
Dashboard error
« on: April 07, 2013, 12:40:27 AM »
The one beside abs error light came up.. Dunno the icon is engine or what... Tried to disconnect the battery for 5mins but it still won't go off... Help needed... Thanks
Offline alvinlee
  • Car Color: black
Re: Dashboard error
« Reply #1 on: April 07, 2013, 12:56:42 AM »
E error
Re: Dashboard error
« Reply #2 on: April 07, 2013, 01:05:45 AM »
It's the engine warning light,it could be the O2 sensor faulty.
Offline alvinlee
  • Car Color: black
Re: Dashboard error
« Reply #3 on: April 07, 2013, 11:15:42 AM »
So what should I do about it??
Re: Dashboard error
« Reply #4 on: April 07, 2013, 11:32:27 AM »
2 things u can do. Go back to your workshop and do as follows:
1) They will reset the ECU and the light will disappear.  You can try driving for a while and see if light reappear again.
2) If appear again, your o2 sensor is faulty.  IT cost 200 - 300 depending on the effort to change the 02 sensor.
Mine 02 sensor was faulty during CNY.  Damage around 320 to change.
Offline alvinlee
  • Car Color: black
Re: Dashboard error
« Reply #5 on: April 07, 2013, 11:39:52 AM »
What kind of damage will e O2 sensor cause?
Offline alvinlee
  • Car Color: black
Re: Dashboard error
« Reply #6 on: April 07, 2013, 11:45:04 AM »
Kelvin, how much does it cost to get it reset?
Offline bakoh79
  • Car Color: Pearl-White
Re: Dashboard error
« Reply #7 on: April 07, 2013, 06:55:10 PM »
Go back to ur workshop.. they shld be able to tell u wats the error.. it could be other faulty sensor tat is causing the ecu to light up..
Offline ecys
Re: Dashboard error
« Reply #8 on: April 08, 2013, 01:40:25 PM »
Did you change your air intake to open pod?
Offline alvinlee
  • Car Color: black
Re: Dashboard error
« Reply #9 on: April 08, 2013, 05:39:31 PM »
Nope..
Offline alvinlee
  • Car Color: black
Re: Dashboard error
« Reply #10 on: April 08, 2013, 05:41:08 PM »
Problem solved.. Thanks to kelvin and his team...  ;D
Re: Dashboard error
« Reply #11 on: April 08, 2013, 10:40:46 PM »
So what was the issue? care to share?
