Author Topic: Latio original spark plug only?  (Read 6360 times)
Offline xavier_xw
  • Car Color: White
« on: October 07, 2013, 12:43:16 PM »
Want to ask fellow Latio drivers about spark plugs, my work shop say Latio can only use Nissan original spark plugs, can not take 3rd party ones (including  Bosch) or will not start.
is it true? Thanks!
Offline ahjie
  • Car Color: blue
Re: Latio original spark plug only?
« Reply #1 on: November 02, 2013, 06:55:33 PM »
My '05 Latio uses Denso Iridium spark plugs. The manual indicates FXE20HE11 as the standard with
service option as FXE22HE11 or FXE16HE11.
Hope this help :smile:
« Reply #2 on: November 02, 2013, 07:09:57 PM »
Latio can only use FXE20HE11,as for Slyphy 2litre and Lefesta all using FXE20HR11.
Offline CamholicX
  • Redline (6000 rpm)
« Reply #3 on: December 24, 2013, 11:02:45 AM »
Hoe often to change spark plugs . Mine already 5 yrs but mileage only 60k
« Reply #4 on: December 28, 2013, 11:02:34 AM »
100k km
Offline m_k_tang
« Reply #5 on: December 28, 2013, 02:22:32 PM »
From what I know for the standard change of spark plugs to be changed or can last around 100k km, manufacturer set standard at this mileage when they test run on the spark plugs at certain or consistent engine temperature, certain humidity level of the weather condition, condition of the engine and driving consistently at certain maximum speed/RPM (for example, only running at maximum 90km/h or around 2000+ RPM and not more than that to reduce temperature and wear & tear on the spark plugs).
Only at these conditions above, the spark plugs can only last around 100k km. If you are driving in Singapore with higher humidity and higher speed/RPM, the optimum condition of the spark plugs may not last 100k km.
This is according to senior Denso spark plug sales engineer I spoke to recently.
« Last Edit: December 28, 2013, 02:28:35 PM by m_k_tang »
