Author Topic: enginr pinging  (Read 8057 times)
Offline starushz
enginr pinging
« on: March 16, 2014, 12:49:34 PM »
Hi guys
Anyone experiencing ur engine pinging and how did u solve it?  Mine is make those clack clack clack sound under low throttle low speed situation. Like when u engage a higher gear and engine not enough power and will go clack clack clack.
Tried those fuel cleaner also no use.
Re: enginr pinging
« Reply #1 on: March 16, 2014, 09:49:15 PM »
Which RON grade of petrol are you using ?
Offline starushz
Re: enginr pinging
« Reply #2 on: March 17, 2014, 08:40:48 AM »
95. But latio is speced to be able to use 92. Thats from the manual
Re: enginr pinging
« Reply #3 on: March 17, 2014, 10:30:21 PM »
Next you may want to check your spark plug.
The rest need your mechanic to take a look :
1) compression ratio
2) crank shaft bearing
