Author Topic: Air con problem  (Read 28630 times)
Offline Oilysticky
  • Car Color: White
Air con problem
« on: January 17, 2015, 11:50:39 PM »
hi
Any latio owners encounter when driving the air con suddenly not cold and come out hot air?
This happens when you are in heavy traffic for a long time.
Offline rongshu
Re: Air con problem
« Reply #1 on: January 19, 2015, 08:43:41 AM »
Yes I had this problem before. Only not cool when jam and the sun is hot. I changed the aircon magnetic clutch at tomika Alexandra village ($200). It worked for 6 months then aircon compressor totally not worked. Changed at Kelvin's workshop ($400).
If you always in the jam like going to JB, change the compressor. The heat really can kill the compressor. If you want to try your luck, then can change the clutch only.
Offline mtong
  • Car Color: maroon
Re: Air con problem
« Reply #2 on: January 26, 2015, 09:44:36 PM »
can anyone advice what wrong with my car ac blower? It is blowing at max speed once I switch on and I cant lower even before my engine get started
Offline rongshu
Re: Air con problem
« Reply #3 on: January 27, 2015, 02:37:53 PM »
Can you describe it more clearly?
If you didn't turn off the aircon before switch off your engine, the blower will blow on once you switch on your car (ON but not ignited engine yet). At this stage, the aircon is not engaged because the engine is not started yet. Maybe the temperature inside your is high so the fan speed is set to high speed.
Offline Waverine
  • Car Color: Latio sports
Re: Air con problem
« Reply #4 on: March 07, 2015, 02:53:51 PM »
My Aircon suddenly start blow hot air after I parked under hot sun for a while. Was working fine before that. Sent car to check and found out the fuse blown.. Mechanic say compressor tio shock liao... So even if just change fuse will happen again... So Bo pian hv to change low... I think third party compressor about $400 plus... Original is about $580... Not from tan Chong of cos...
Offline Dec7f
Re: Air con problem
« Reply #5 on: September 29, 2015, 07:03:40 PM »
Hi Bro & Sis,
Air con getting not cold..
When on ac, can hear big sizzling sound from alternator, i think it's from alternator.
The sizzz sound when we on air con but now the sizzzz always on,
if off ac, no more sound...
Any idea what is happening?
Estimate repair cost... :unsure:
Jan 09 car, mileage near 100k, bought 2nd hand...
« Last Edit: September 29, 2015, 08:46:10 PM by Dec7f »
Offline rongshu
Re: Air con problem
« Reply #6 on: September 30, 2015, 12:16:01 PM »
Could be leaking from cooling coil. Maybe around 400 to fix it.
Offline Dec7f
Re: Air con problem
« Reply #7 on: September 30, 2015, 12:34:52 PM »
 :thumbsup:
Went yishun ind park A ws today, topped up gas @ $20.. The sizzling sound also gone..
Same verdict from ws, suspects small leakage on cooling coil, including original parts, ac filter & labor, quoted $350...
Said latio coil very small, preferred to use original else..
2~3 hrs job wo tearing down dashboard as access from bottom..
Cheaper to do in jb?
Btw, how does latio cooling coil looks like? :confused1:
Re: Air con problem
« Reply #8 on: October 03, 2015, 11:57:43 PM »
Last time around Q4 2014 JB quoted me around R$900, unsure is it still the same price thou.
Offline ordiofile
Re: Air con problem
« Reply #9 on: November 02, 2015, 09:23:32 PM »
My Latio 4AT Air Con required Gas Top Up after every 4 weeks of driving, since Dec 2014.
From June 2105 onwards, need to top up gas every 2-3 weeks.  Need to pay Mechanic $20-$30 for every gas top up.
Once my Mechanic saw me coming back for gas top up within a month, he suspect Latio Cooling Coil is leaking out gas slowly and may require > S$400 to replace (excluding labour).
As my car is approaching the scrap date in Mar 2016, No point in paying so much money to replace the Cooling Coil.
Also not wanting to pay $20 for every Gas top up in 2-3 weeks frequency, I bought a R134A refrigerant tank (S$110) as well as relevant Low valve R134A connectors with Gauge.
Now I do my own DIY Gas Top Up once my air-con starts to blow out less cold air.
Don't consider this DIY a good investment, but more like $$ damage limitation :(. Until my car is scrapped :crycry:.
My symptom may not be the same as yours. But some info sharing:
- Air Con not as cold as it used to be. After half an hour drive, you are better off winding down the windows.
- Measured Pressure on the "L"ow pressure Valve, with air con on (and high fan speed), only got 20-25psi.
- Pump in R134A until "L" pressure reads 40 psi.
Re: Air con problem
« Reply #10 on: November 03, 2015, 08:57:06 PM »
Seem like yours is a big leak, I top up every 6 months.
Offline latiosnow
Re: Air con problem
« Reply #11 on: December 08, 2015, 08:51:47 AM »
hi
Hi Bro, you are not alone, I also have the same air-con problem despite replacing the coil 2yrs back. Only on rainy days or night the air-con function normally. In the hot & sunny day, it will blow out hot air. I always have to turn off the A/C button for a while and turn on after a min or so, than the air-con will blow some cool air. But this steps have to repeat several times if I drive long dist.
Lately, when I engaged my "R" gear, the car will take up to 3 sec. to respond and gave a jerking (gear engaging jerk) to start the reverse. Any bro experience this issue? Is it a sign of gearbox failure?
Anyway my list go (suspension sink a bit on the right etc...) on for my ageing Latio Sport which serve me well over 9yrs 9mths (only 150,000km).
Re: Air con problem
« Reply #12 on: December 09, 2015, 07:15:50 PM »
Just to add on my encountered regarding this aircon issue.
My aircon recently not cold anymore so today decided to go Defu Lane for top up, the mechanic told me my aircon gas is full, so propose me to do a aircon flush which cost me $120. He told me compressor has a lubricant as well which is like plain water color, what mine is already milky slimy green in color. So he ask me to monitor for the next few day to see if the aircon perform well else it would be most probably my fan coil need replacement.
Offline wstan
  • Car Color: Silver
Re: Air con problem
« Reply #13 on: January 16, 2016, 02:50:13 PM »
My Latio Aircond all of sudden blowing hot air.
Went to Kelvin's place to check, turns out to be magnetic coil issue. Got it replaced, and is now a happy car user all over again.
I am always skeptical when it comes to auto workshop, but Kelvin is really is the guy that will give you confidence to go ahead with the repair.
Very knowledgeable (fast trouble shooting), skillful (when changing parts), price reasonable and most importantly HONEST.
Air cond blowing hot air could be cause by several reason, go and let Kelvin (ERA Auto) do a check up, you will not regret it.
Thank you Kelvin !
Offline kenmaine1008
Re: Air con problem
« Reply #14 on: August 08, 2016, 01:14:35 AM »
hi bros, sorry to revisit this thread.
my latio is having sizzing sound at interval timing(last a few secs) when aircon is switched on; aircon is cool though and no warm air blown out. The sound is gone when aircon is switched off.
does it need gas top up? or require cooling coil change?
Le Kua Simi? (x 2)
see my super chio rim~
Le Kua Simi?
my car more swee~
Offline inspiring1804
  • Car Color: White
Re: Air con problem
« Reply #15 on: August 08, 2016, 08:29:05 PM »
I think the sizzling sound is normal when the air on compressor cuts in at regular intervals and release aircon gas. I have this sound for as long as I drive my latio coming 8 years. If you hear sizzling sound continuously, then it's not normal. For my case is aircon gas gone, I top up gas and it lasted abt 4 months before needing another top up probably coil leak... But not sure if I will repair coz I could be scrapping my car soon. Unless iam renewing Coe...
Re: Air con problem
« Reply #16 on: August 09, 2016, 01:17:29 PM »
Thanks Inspiring bro for the information. But i remb when latio was new there isn't any sizzing sound. Thus was worried if it is aircon gas leakage/cooling coil spoil or something else major.  :crying:
Le Kua Simi? (x 2)
Le Kua Simi?
my car more swee~
  • Car Color: White
Re: Air con problem
« Reply #17 on: August 09, 2016, 06:39:29 PM »
I think the sizzling sound is normal when the aircon gas is released. But the sound should only be a couple of seconds and then disappear. Then come back again when compressor cuts in and gas release again. I recently just topped up gas again. The last round lasted 4 months. I see this time how long it will last. Probably shorter. Coz I believe the leak will only get worse.
Offline rongshu
Re: Air con problem
« Reply #18 on: August 10, 2016, 11:53:03 AM »
I also have this sizzling sound for a few months. I have changed cooling coil and compressor 1 year ago. So hoping it is normal. Will ask workshop to check if any leaking during next servicing.
