Author Topic: Need Help on a 2nd Hand Latio Premium  (Read 20265 times)
Offline Raybies
« on: September 08, 2015, 07:37:05 AM »
Hi Guys,
I just bought a 2nd hand latio but having slight problem with the car. Problem is when i accelerate can hear metal clanking sound in the engine bay so i brought it to a workshop. According to the technician, he said that the timing chain is stretched that is why hitting and creating the sound. Will this happen as our engine is running on timing chain?
Any folks encountered this before?
Re: Need Help on a 2nd Hand Latio Premium
« Reply #1 on: September 13, 2015, 04:36:03 PM »
Did the mechanic re-tension the timing chain for you ? Else change a new one.
Offline Raybies
« Reply #2 on: September 14, 2015, 07:47:46 AM »
Nope I went to autoaid and according to them timing chain needs no replacement they mentioned most likely due to pinging from the engine. My question is did anyone really changed their latio timing chain?
« Reply #3 on: September 14, 2015, 04:12:04 PM »
never changed timing chain b4, thought timing chain no need change?
try calling other workshop for a 2nd opinion.
« Reply #4 on: September 14, 2015, 08:54:23 PM »
Hi Guys,
Hello, what's the mileage like? The last time it happened to my Latio, it was the CVT gearbox needing overhaul @ 220,000KM.
Offline Raybies
« Reply #5 on: September 15, 2015, 09:04:06 PM »
Mileage is like 110,000km. Brought to another workshop autpaid said is the engine pinging sound ask me to try esso or caltex 8000.
Offline Raybies
« Reply #6 on: September 15, 2015, 09:09:32 PM »
The sound is pretty obvious is coming from the engine portion. Gearbox is located more on the front bottom or bottom portion of the car right?
« Reply #7 on: September 18, 2015, 10:01:10 AM »
Timing chain can be replaced, only tedious process. Let the guru from the web tell you.
http://www.testingautos.com/when-does-the-timing-chain-need-to-be-replaced
If it is engine pinging, try to top up higher RON or octane petrol see if this improve.
http://repairpal.com/what-is-engine-pinging
Offline Raybies
« Reply #8 on: September 18, 2015, 04:56:16 PM »
Wow thanks for the advice bro. Just curious did anyone even changed out their timing chain here? Cause the mechanic told me if the timing chain is stretched, even the engine has started will hear the sound. Don know how true is that
« Reply #9 on: September 28, 2015, 05:14:10 PM »
So far, as per my humble knowledge and from mechanics which I like to TCSS with them, usually MT performance cars will have the tendency to replace timing chain due to the nature of the habitual driving. For normal AT and CVT, it really need a high mileage to wear a timing chain since it come with a chain tensioner as built in for most cars nowadays.
What the mechanic said is true if timing chain is worn and stretched as it will vibrate thus that where the sound should be.
So have you solve your pinging noise yet ?
Offline Raybies
« Reply #10 on: September 28, 2015, 05:44:39 PM »
Not really solved as I have yet to try out caltex 98 due to my sales job using only esso petrol card I can only make do with esso5000. I have brought to Kelvins workshop though and autoaid And both offer same advice. If timing chain stretched, accelerating in Neutral mode should have the sound already which in my case is not what happening.
« Reply #11 on: October 03, 2015, 11:54:11 PM »
True. But there is esso8000 fuel you can try right ?
Offline Raybies
« Reply #12 on: October 04, 2015, 07:28:34 AM »
Bro, my petrol card is strictly for Esso5000 no other choice.
Offline dthh
  • Car Color: RED
« Reply #13 on: October 05, 2015, 11:33:19 AM »
Suggest use own pocket $$ for 2 full tank can liao.
1 tank for switch over (run in ) second tank for monitoring.
This will give you an answer.... :yehyeh:
Offline Raybies
« Reply #14 on: October 05, 2015, 08:35:32 PM »
Ya will try this month super broke with changing battery,spark plugs, engine mount and now suspected compressor going to uplorry soon sia
Offline dthh
  • Car Color: RED
« Reply #15 on: October 06, 2015, 01:27:42 PM »
Wah....buying a car and yet need to change so many item....not really worth....
Unless you already drove for few months...
Waiting your feedback on mention issue...
Offline matrix
« Reply #16 on: October 24, 2015, 01:56:37 PM »
Should just evoke lemon law on this one.
Offline Raybies
« Reply #17 on: October 25, 2015, 08:07:16 AM »
To be honest after surfing the forum, came to realised latio has its own fair share of problems. As long as the car can move till next year I will consider it lucky.
