Author Topic: Power Window Issue  (Read 15746 times)
RR
Power Window Issue
« on: June 19, 2006, 11:53:34 PM »
Lower the driver's  window till fully open and then  move it up till it closes and continue to hold the lever up for another 4 to 6 secs & then release the lever. now, lower the window down fully again & lift the up lever for 2 secs, it should auto close. repeat the procedure if it don't work as the timing is important.
For issues concerning front passenger seat window -> can wind down but cannot wind up using driver's side window control, had to use the passenger's side to wind up manually. Go back to TCM to have the motor changed.
