Author Topic: Newbies HELP thread, ask vypez anything!  (Read 163927 times)
Offline vypez
    • need help with words?
« Reply #140 on: January 14, 2008, 11:40:04 PM »
bro, you super DIY man leh.
alternator, look carefully. dont remove the wrong bolt or else the whole alternator will slide down.
and.. need to ground tb meh?
Offline Terenc3
« Reply #141 on: January 15, 2008, 01:06:40 AM »
Haha.. most of my stuff i DIY.. got fun and feeling to my own car mah.. TB got people say ground good, my sunny i got ground la.. Haha.. Any rough guide on which exact bolt shd I go for, for alternator?
Offline vypez
« Reply #142 on: January 15, 2008, 11:31:11 PM »
no idea.
not driving latio anymore.
Offline rocket
« Reply #143 on: January 22, 2008, 01:29:21 PM »
vypez:
what is the capacity of our Latio battery?  45AH or 60AH?
Any problem ( eg. under charge) If I change to a larger one?
Offline vypez
« Reply #144 on: January 23, 2008, 10:07:44 AM »
vypez:
big is good. =]
Offline rocket
« Reply #145 on: January 25, 2008, 11:11:46 PM »
thanks
Offline PTC77
  • Nismo LaTIo
« Reply #146 on: January 27, 2008, 10:28:44 PM »
do u know how much will it cost to replace the antenna base unit on my latio sports rooftop, the plastics unit connecting the antenna somehow is broken
Offline vypez
« Reply #147 on: January 28, 2008, 01:43:40 AM »
no.
Offline Terenc3
« Reply #148 on: February 02, 2008, 07:53:57 AM »
no.
how to change the  LED bulb of the front roof lighting? The one that comes with the sun glass holder.. Dun wan anyhow poke poke later scratched.. Lolz..
Offline vypez
« Reply #149 on: February 02, 2008, 12:40:07 PM »
you got to drop the whole assembly incl the whole plastic part.
Offline Terenc3
« Reply #150 on: February 02, 2008, 04:03:54 PM »
So I just pull off the whole front plastic? or use a flat head to stick where?
Offline zzzz
« Reply #151 on: February 09, 2008, 07:22:09 AM »
started this thread to answer question from newbies, but please, search before you ask. =]
let the questions begin..
bro, wan to check with u on the AC...
if we set to 25'C, or 20'C, how the ac system work? do it get the specifed temp via the mixing of the hot air and cold air ? or the compressor is varaible? or a thermostate to cut in /off ??
next ?, how to set a reply or a reminder email if the forum topic of mine is been replied ?
tks
Zzzz = z4
Offline vypez
« Reply #152 on: February 09, 2008, 02:04:57 PM »
for the aircon, setting it @ 25 will result in a mix of hot and cold air if running on auto mode. once it hits 25c, it will cut off. compressor will always pump out cold air. if hot air is needed, it simply draws from engine bay.
er.. i think it's under profile. you can set a reminder. not too sure about this. technical questions can lah..
Offline zzzz
« Reply #153 on: February 10, 2008, 09:24:10 AM »
bro,
thks for yr reply.
the reason i am asking was that i find that the air at 25'c is not cold and it is sometime only....let say,if normal case, when just start the engine and you set at 25'c and at auto, it should be blowing cold air right??
Zzzz = z4
Offline vypez
« Reply #154 on: February 10, 2008, 02:54:40 PM »
bro,
thks for yr reply.
bro, car's compressor not as strong.. thus sometimes may not be too accurate. it takes a little while to cool down.. =]
Offline hotcake
« Reply #155 on: February 11, 2008, 03:47:20 PM »
Hello...i am going to ask a question which pple may think WAH LAU EH!!!
Anyway i am going ahead.....
1.Our latio battery is liquid right?
2.How long need to top up?
3.Where and what brand of battery water should i use and buy?
4.Can i change the battery to those non-liquid type?? If yes where can i find it? TCM have?
Thank u sooo much.....
 :confused1:
Offline zzzz
« Reply #156 on: February 12, 2008, 09:53:46 AM »
 :confused1:
Yes
no fix timing, see if the batteries screw cap is dry , then you need to top up liao..
Me cheapo...i use the office pure drinking water (distilled)
Yes, you can request them and at a certain topup...
Zzzz = z4
Offline Symbolic
« Reply #157 on: February 13, 2008, 11:43:00 PM »
Any fellow Lation experience v poor torque when going up slope, e.g. ECP towards Keppel, noticed RPM 2K, then 60Km/h, even try to whack harder on pedal, still moving v slowly  :confused1: :confused1:
Not sure if this is normal for Sedan AT ? Like no power like tat  :( :(
Hope some Lation can share, thanks !
Offline kenny59
  • C'mOm Let'S Play...
« Reply #158 on: February 14, 2008, 12:14:30 AM »
hi vypez,need u to advise me on which engine oil to buy for my 10k svc on fri.most of the time i floor my car rpm fr 3-4k onwards when driving on the road.heard tat armsoil not bad but where n how many litre much i get n wats the cost??? ;Dhope u reply soon,thxs
Offline latioboy91
« Reply #159 on: February 14, 2008, 12:28:57 AM »
Bro
Amsoil 5w-30 can be gotten from Terence from Mxtradings at 15 per quart.
Done it on my latio on 60k servicing. SHIOK is the word !
