Author Topic: Newbies HELP thread, ask vypez anything!  (Read 161550 times)
Offline JLHeng
« Reply #260 on: February 08, 2009, 11:21:19 PM »
hi!
i think i saw it in Silent b4. hope this help
Oh! Is it? Thanks bro. Will check it out.
Cheers!
Offline dc100
« Reply #261 on: February 15, 2009, 10:01:19 PM »
hi tinking of getting a latio...
1. how much is the ATF?
2. anyone used platinum tipped sparks?
3. anyone install SAFC NEO, VAFC, or SAFC on their rides? did it give better FC?
2. any recommended workshops?
thanks!
« Reply #262 on: March 03, 2009, 12:24:42 AM »
Hi all, like to ask if latio is equipped with fuel filter? If yes, do we need to change the fuel filer? When to change and how much? Sorry to ask this question as can't find any thread on this subject matter. Thanks.
Offline vypez
    • need help with words?
« Reply #263 on: March 21, 2009, 03:26:45 PM »
thanks!
1. no idea. sorry.
2. latio's stock plugs are good stuff. stick to them. =]
3. depends on what you tune it for doesn't it? plenty of latio .. i know of. =]
4. for? dropping in engine or simply servicing?
Offline vypez
« Reply #264 on: March 21, 2009, 03:27:26 PM »
all cars has fuel filters. dont worry too mcuh bro. 10years, the car wont spoil. =d
Offline ket
  • Fat Ket
« Reply #265 on: March 28, 2009, 11:44:14 PM »
Hi Vypez, could like to ask you, how long do we need to service or change the aircon filter? And where is the aircon filter?
My Latio is going 2 year old this coming July.
Thanks a lot.
« Reply #266 on: April 06, 2009, 11:55:38 PM »
Hi vypez, thanks for the info. Thought it's like my previous old car which req to change the fuel filter at certain milleage. Thanks :thumbsup:
Offline SpeedLimit
« Reply #267 on: May 03, 2009, 04:47:46 PM »
Hi bro,
install of lowering spring need to do any alignment? or just fix and run... ;D
I am looking out for workshop to install and would like to know more about installation.
thanks
Offline vypez
« Reply #268 on: May 04, 2009, 11:26:11 PM »
better to do alignment.. =]
workshops prob can try out Man Exhaust or AT Performance, both at Sin Ming Industrial park block 14.
installation is pretty straight forward. =]
Offline gracieg
« Reply #269 on: May 04, 2009, 11:38:29 PM »
hi vypez, are you a boy or girl?  :D
Offline vypez
« Reply #270 on: May 04, 2009, 11:49:52 PM »
hmm.. i am not too sure. why dont you tell me?
Offline Hirofumi
« Reply #271 on: May 08, 2009, 07:21:44 PM »
Hi All,
I jsut got my car not too long ago, but not sure about the Fuel Consumption for the Latio Sedan.
I am driving the premium sedan version and somehow i feel the FC seems to be abit on the high side. I did a reset of the the distance travel when i got a full tank and start to monitor.
It seems like I took 1/4 tank to travel about 60~62 KM. is it normal? Or is there some problem. My family had a slight mishap before durign the first few weeks, when reversing the car, they went too fast and the back where the hook is hit the kerb real hard, could it be the cause?
Appreciate if anyone can tell me if that's the normal consumption? Thanks. :crycry:
Offline vypez
« Reply #272 on: May 08, 2009, 09:17:39 PM »
Hi All,
if your car is still within its first 5000km, i'd advise you not to worry too much about it as you're still running in the engine.
dont base anything on first 1/4 tank, base it on 1 full tank, till light up. pump to full(make sure its the same pump, same pump attendant) and calculate based on that.
distance travelled / litres pumped = FC.
you should be clocking about 12km/l.
as for the accident, no problem. except that your exhaust might be affected and leaking, thus causing loss of power and you revving more.
cheers bro. do check and revert. =]
Offline Monster
« Reply #273 on: May 14, 2009, 07:21:21 PM »
Hi newbie here,
I got my Latio in January but unfortunately the car met a rock on the highway and causes my rear rims on the driver side dented....heartached!!!
My bro changed the rims to 16" kyowa rims and with firenza tyres...the ride seems more stable but i have problem when i travelling at 90km/h onwards (My normal speed on highways always approx 100-110km/h) as i sense vibrations..
I have done a few times balancing but the problem still persists.  :crycry:
1)Wonder if i should go for high speed balancing?Where to go to do it?
2)Is there other alternative?
Thanks. :smile: :smile: :smile:
Offline vypez
« Reply #274 on: May 14, 2009, 10:57:39 PM »
Hi newbie here,
balancing done where?
hmm.. probably can try out alignment. =]
might help. just might.
Offline Monster
« Reply #275 on: May 19, 2009, 09:53:55 AM »
Thanks.Will go do and see. :smile:
Offline Huatster888
  • TAI KAY LAI HUAT AR!!!
« Reply #276 on: May 26, 2009, 04:44:03 PM »
long time no c mr eessack!!!anti roll bar ??ur loh bang still hve??just anti roll nia, isit front n back lower???how much??tanks
Offline vypez
« Reply #277 on: May 26, 2009, 05:41:05 PM »
si ah huat. msn lah!
Offline Huatster888
« Reply #278 on: May 27, 2009, 09:15:17 AM »
dun reali used it much liao , dont c me liao on msn , dun u tink so
tok here lah ahahaha
Offline Covin
    • covinmakeup@bravehost.com
« Reply #279 on: May 31, 2009, 10:24:05 PM »
Hi vypez
What is a sparkbridge?
