Author Topic: Noise from Boot.. & Tyre Change  (Read 10854 times)
shene
« on: April 12, 2008, 10:45:23 PM »
Hi Hi,
Anyone exp noise from the boot?
Its like "knocking" kinda noise...
sth like pail handle keeps knocking the boot.. "knock knock"
Recently keep hearing that.. removed everything from my boot le, noise still persist!
My milage is abt 38K now... shd i start changing my tyres? If so, what brand?
Currently on Dunlop Sports, changed since first month I had my car...
Pls advise!
Many thanks!!
Offline Novellus Legends
  • Eye Power !
Re: Noise from Boot.. & Tyre Change
« Reply #1 on: April 12, 2008, 10:48:01 PM »
sometime i also encounter similar noise , thought i ran over a balloon or wat , nevertheless , car still can move , FC still intact , ok la..
since man can see supernatural , inevitably also can hear supernatural i guess
Me&my TiidaLatioZ
shene
« Reply #2 on: April 12, 2008, 10:50:38 PM »
But somehow its getting on my nerve!
Had this noise after an accident in Feb this year!
Went to the workshop, they say they cant do anything!
Pissed off! :uppercut:
« Reply #3 on: April 12, 2008, 11:50:46 PM »
does the sound persist only when u brake? or is it constant? is it also rhythmatic? according to the rpm of the wheel?
shene
« Reply #4 on: April 13, 2008, 12:16:03 AM »
when i drive slowly, i can hear the noise more clearly... when i am driving at high speed, it is less obvious!
The noise is during my drive.... not during brake. :(
Offline ket
  • Fat Ket
« Reply #5 on: April 13, 2008, 07:10:54 AM »
Maybe something happen to the body frame? Maybe!!  :confused1:
« Reply #6 on: April 13, 2008, 08:44:54 AM »
Hi Hi,
Pls advise!
Many thanks!!
previously my latio sport oso have some knocking noise when i go over uneven surface....complained to TCM and they adjusted the cylinder & lock.....then ok liao no noise....
so if urs is sport version, try asking TCM to adjust that....
shene
« Reply #7 on: April 13, 2008, 10:42:34 AM »
yup yup, mine is sports version.
so I guess have to go back to TCM and bug them again!!! :(
*cyclinder and lock*
Thanks for the info!!  :smile:
shene
« Reply #8 on: April 13, 2008, 10:44:31 AM »
 :crycry: :crycry: :crycry:
« Reply #9 on: April 13, 2008, 10:59:10 AM »
me oso same as u....removed everything from the boot and drove around....noise still persist....so go back to TCM & everything ok after that.....
shene
« Reply #10 on: April 13, 2008, 11:10:17 AM »
Think I will go do it during my 40K... which is probably one month away.
in the mean time... got to endure lor... sob sob
Btw what tyres are u using? think i need to change mine le :smile:
Offline skycurler
« Reply #11 on: April 13, 2008, 11:42:14 AM »
My latio sports used to have the strange noise of some stuff rubbing together from my boot.
I also try to remove everything from my boot and the sound still there.
Then i ask my friend to sit at the rear to trace the origin of the sound.
But whenever ple st behind, the sound is gone.
Later i found out that the sound is caused by the rear sit rubbing against the side of the rear pillar.
I used leather conditioner to touch up the contact surface between the seat and the pillar side, the sound is gone....
shene
« Reply #12 on: April 13, 2008, 11:52:24 AM »
hm..... most of the time i drive ALONE!
maybe later I try yr method!
Thanks for sharing!
« Reply #13 on: April 13, 2008, 02:44:37 PM »
Thanks for sharing!
my rear seat is 1 click away from the max.....me using GR80 now....
Offline blitz
« Reply #14 on: April 19, 2008, 10:27:24 PM »
Hi sky, when you say u removed everything from the boot, does it include the spare tyres and toolkits?, cos I found out my problem with the noise was the toolkit that is not secured...
Offline psyched
« Reply #15 on: April 19, 2008, 10:33:52 PM »
Hi Hi,
Pls advise!
Many thanks!!
i also got the "noise" at the boot.
it turns out to be at the holder of the CD changer. it was not properly secured.
shene
« Reply #16 on: April 19, 2008, 11:15:07 PM »
As for me.. I din remove the spare tyre....
toolkit removed...
 :crycry:
shene
« Reply #17 on: April 19, 2008, 11:20:36 PM »
my CD changer is below my passenger seat (stock)
so i dun think thats creating the prob!
anyway now 38K... soon 40K ...
will go TCM to bug them again!
Offline Tan
« Reply #18 on: April 20, 2008, 09:09:41 PM »
may be it is the exhaust muffler noise, check if it is dented.
Offline skycurler
« Reply #19 on: April 21, 2008, 03:31:09 AM »
Hi Blitz,
I didnt remove the spare tyres.
I only manage to stop the noise when i release the rear seat and lay it flat.
So i suspect might be some sort of rubbing or the seat latch is loss.
