Author Topic: My FC getting worse.......help!!  (Read 311714 times)
« Reply #280 on: July 19, 2008, 03:45:21 PM »
Guys try pump ur tire. After i pump FC improves back  :smile:
hello,congrat man.
but boi chun one lah. Relax.
« Last Edit: July 19, 2008, 03:49:37 PM by iagree »
« Reply #281 on: July 19, 2008, 04:10:02 PM »
Other than inflating your tyres, make sure your wheels are properly aligned, and tyres balanced too.
Misaligned wheels cause unnecesary friction and wear and increases fuel consumption too.
« Reply #282 on: July 19, 2008, 09:29:56 PM »
To add on, make sure of proper servicing, especially changing of engine oil to protect your engine... ::)
« Reply #283 on: July 21, 2008, 10:03:40 AM »
i do agree on this but for me>> have to wait for my 10K or 15K servicing then can change engine oil leh
so it so far far away :crycry:
« Reply #284 on: July 22, 2008, 04:28:45 AM »
Latio synthetic engine oil change interval is 10K km, not 15K km.
But Daihatsu oil change interval is 15K km.
Which makes me wonder why some oils can last 10K km while some can last 15K km.   :confused1:
« Reply #285 on: July 22, 2008, 08:08:06 AM »
actually not only the oil.. the oil filter also plays a part.
« Reply #286 on: July 22, 2008, 09:58:39 AM »
Engine oil will deteriorate in its capability to lubricate the engine after extended use.
« Reply #287 on: July 22, 2008, 10:31:28 AM »
actually somebody pls educate mi. the engine oil collects also all the deposits and dirt etc thats why it turn black, so usually mineral oil at 5k u change it, it is already abit blackish and contaminated... by 10k those using synthetic oil is black black already... isn't it better to just keep changing mineral oil in this case?
« Reply #288 on: July 22, 2008, 10:49:16 AM »
« Reply #289 on: July 22, 2008, 01:12:17 PM »
Offline petra74
« Reply #290 on: July 27, 2008, 01:23:39 PM »
That is why I use Lube Control 20 for my engine oil and FC 60 for my petrol, you may visit this website for more info: http://lubecontrol.com/
Clean, Lubricate and Protect Both Sides of your engine for Optimal Performance!
"... for King and Kingdom..."
« Reply #291 on: July 27, 2008, 01:44:01 PM »
Hi, may be another alternavtive is the
ENGINE CARBON REMOVAL service @ SGD$20 from htyre@Bendemeer road
Short start-stop driving trips as well as prolonged idling are the main causes of carbon deposits in the combustion chamber. Carbon deposits on the back of intake valves can impede air flow & cause a loss of high speed power. It also causes hesitation problems by absorbing fuel spray from injectors.
The blasting equipment softens, loosens and removes stubborn carbon deposits. The results can be felt immediately with your petrol burned more effectively bringing about higher engine performance.
Come down to have your engine carbon removed at SGD$20 per flush.
« Reply #292 on: July 29, 2008, 09:09:36 PM »
Juz a noob qn: does TCM provide this during our servicing interval?  :confused1:
gvyong
« Reply #293 on: July 29, 2008, 09:37:13 PM »
Hi all
this is my 1st noob post  ;D
am getting strictly 11.5km/l, 80% city, 20% hwy.
something interesting on yahoo (video) today:
"UPS saves money, 3 million gallons of fuel just by turning right"
http://www.yahoo.com/s/925067
in Sg, since we drive on the LEFT, wonder if we can do the same and save on ga$ by turning LEFT  ?
ie. plan (re-plan) our travel routes to minimize right turns that cut across traffic, which has higher probability of stopping to give way to oncoming traffic as compared to left turns.
« Reply #294 on: July 31, 2008, 08:54:52 AM »
Hi Bro, Can share what is the full address and how long the flushing takes?  Thanks.
« Reply #295 on: July 31, 2008, 02:42:10 PM »
Hi all
very interesting.. it makes a lot of sense .. but it's not about turning LEFT.. if u turn LEFT into a jam infront of you, your FC also chui. the point is to avoid as many start/stop as possible  :thumbsup:
« Reply #296 on: July 31, 2008, 02:53:22 PM »
46 Bendemeer Road,Singapore 339931 ,Tel: (65) 6293 3636
whole process shd be less than 1 hr.  Intend to try this service later
Offline rocket
« Reply #297 on: July 31, 2008, 03:17:56 PM »
please share with us your experience and FR after try the service, thanks
« Reply #298 on: August 02, 2008, 12:53:42 AM »
Thanks, Bro.
Offline xuan511
  • Latio is a good car
« Reply #299 on: August 03, 2008, 02:35:26 PM »
Bro u tried already?
Loving My Whitey
