Author Topic: My FC getting worse.......help!!  (Read 311786 times)
Offline hct
« Reply #60 on: April 30, 2008, 04:28:46 PM »
try to look at all the pumps in the station... I heard for some stations, only 1or 2 of the pumps provide all the 3 grade..
Offline walker
« Reply #61 on: April 30, 2008, 04:39:44 PM »
Just to share some interesting experience on FC.
I have very consistently gotten 14+km/l for every full-tank pump for the past 1 year. However, on a couple of once-a-blue-moon occasions, a particular full-tank pump would only yield a low 12km/l. It will then return to consistently 14+km/l on subsequent pumps. The sharp peak in FC for such one pump is very noticeable. When such phenomenons happen, there are no servicings in between nor change of drivers, travelling routes between pumps etc. I am not sure I am alone in this experience.
« Reply #62 on: April 30, 2008, 05:10:28 PM »
Thats good for constant 14km+. Mine is up n down..  :(
« Reply #63 on: April 30, 2008, 06:53:46 PM »
yeah walker, same here.. normally i would refill 40l fuel , usin the same grade, travellin the same route daily on a constant speed at times i can clocked 610km max but sometimes 500km light appears liao... funny & weird it has been happenin for the past 1yr
« Reply #64 on: April 30, 2008, 09:20:58 PM »
 :blink: My best record is 470k only.....500-600km cannot imagine? travel highway often huh? or is it yours a premium?
Offline maverick1975
« Reply #65 on: May 01, 2008, 07:55:11 AM »
whats our tank capacity?
Offline rodrigue
« Reply #66 on: May 01, 2008, 10:06:03 AM »
anyone heard or tried on the EPS Saver? does it really reduce ur FC??
« Reply #67 on: May 01, 2008, 10:24:36 AM »
Offline gh05tss
« Reply #68 on: May 01, 2008, 11:42:47 AM »
45L
My last full tank of 45L, light up at 372km....am I facing some problem here?
« Reply #69 on: May 01, 2008, 03:56:45 PM »
When light lit, there should still be reserve of about 7-8 litre.  Assuming that you have top up your tank, this means you had used about 37-38 litre for 372 km.  This FC about 10km/L does not seem impressive as some bro/sis here get 14-16 km/L.  Of course, this depend on your travel pattern too.  Myself, so far, best is 14+ and worse is 12+ km per litre.
« Reply #70 on: May 01, 2008, 05:48:04 PM »
quite normal lah. dun wori. my previous tank only gv me abt 365 km nia  :crycry: but used to it liao. dun think got anytime over 400km mark  :weep:
Offline gh05tss
« Reply #71 on: May 01, 2008, 06:12:49 PM »
Envy yr figures...travelling pattern...travelling most during the usual rush hour with Jam.
Offline gh05tss
« Reply #72 on: May 01, 2008, 06:18:32 PM »
What's yr figure now?
Offline kanzo
« Reply #73 on: May 01, 2008, 08:29:25 PM »
I have my tyres at 265kPa up front and 235kPa rear. At these pressures, I don't think we have to worry about uneven wear on the tyres. Most tyres are more prone to uneven wear from underinflation. Also, inflating to higher pressures means the tyre suffers less deformation while rolling at high speeds and that contributes to lower operating temperatures on the highway.
One crazy theory I have is that TCM technicians have to rev the engines hard as part of their checks and this may upset the ECU somewhat so that you may need to "teach" the ECU to return to your usual frugal fuel sipping drive style.
I think 12km/l for 10%HW is an excellent figure. It is very difficult to get good mileage with A/C blasting and if you make only short trips. The engine is rather inefficient before it reaches operating temperature. Also, a cold transmission has a nasty habit of not locking up the torque converter.
Try to:
- Time traffic lights so you don't have to stop
- Leave more space in front of you so you brake less often
- Turn off your engine at stopped at lights that take forever to change- Do not warm up you engine by idling. Just start and drive off at a relaxed pace
u sure abt this bro..??
« Reply #74 on: May 01, 2008, 10:33:25 PM »
You drive like a Rex?  :blink:
« Reply #75 on: May 01, 2008, 10:54:01 PM »
or his car behaves like a rex?? :bleh: :bleh:
« Reply #76 on: May 01, 2008, 11:05:38 PM »
Dear Bros & sis
I confirm the following observation...
My driving conditions worsen lately a bit...more jams, changed to Esso 5000 full tank on my last pump last Friday, only today I need to top it up, mileage clocked is 421.5, pumped a total of 38.75L, I turn on aircon all the way, no more shutting off aircon..
Conclusion, despite worsen driving conditions, changing to Esso 5K seems to improve mileage and pickup power. last time when I use SPC 98, can manage only at best 380, plus I off air-con frequently......
« Reply #77 on: May 01, 2008, 11:14:36 PM »
Dear Bros & sis
Only 1 tank and you able to conclude? No hurry, run a few more tanks first.  :smile:
« Reply #78 on: May 02, 2008, 01:15:37 AM »
before that I already tried Esso before, but that was before i get Esso card, so I stop for a while use SPC,
I tried before Esso5000 and 8000, gave me very good mileage, Caltex too, 4 Tanks of SPC later I come forum here to scream for help..
so now U know why I conclude...
Offline BlackieLatio
« Reply #79 on: May 02, 2008, 09:13:05 AM »
My personal opinion, don't waste your money on magnet kinda stuffs. If a $99 magnet can perform miracle than it won't be so cheap liao.
