Author Topic: Battery Water  (Read 13134 times)
HJB
Battery Water
« on: June 26, 2008, 04:56:26 PM »
Can I use normal tape water to top up our battery or must buy those battery water?
Got mixed info from different sources  :confused1:
Re: Battery Water
« Reply #1 on: June 26, 2008, 05:01:29 PM »
must use distilled water (battery water)
tap water will damage the battery = need to spend $$$$$ to change battery when it konks out prematurely
HJB
Re: Battery Water
« Reply #2 on: June 26, 2008, 05:06:25 PM »
Thank you very much .... that joker must be aiming to sell me new batteries  :glare:
Re: Battery Water
« Reply #3 on: June 26, 2008, 05:12:46 PM »
wahahaha
who is that joker?
battery is about $80 to $90 (normal one)
battery water = $1
HJB
Re: Battery Water
« Reply #4 on: June 26, 2008, 05:17:19 PM »
Saw some said our battery last 1-2 yrs only?
My old ride has a maintain-free battery and i didnt change for 3++ yrs :P
Re: Battery Water
« Reply #5 on: June 26, 2008, 05:24:14 PM »
batteries normally can last about 2 years
however, in new cars, it may depend on your luck as you don't know how old is the "normal" battery when it is installed in the car at the factory
maintenance-free batteries just mean that you don't need to top-up battery water
just make sure you check the indicator regularly
Re: Battery Water
« Reply #6 on: June 26, 2008, 10:07:47 PM »
Hi HJB,
Initially used battery that can top up water, lasted me abt 3 years for my prev ride before changing. Currently using Bosch maintainence-free battery that don't need to top up battery water ones, can last abt 2.5yrs ba...Changed from my father-in-law....can PM me if u need to change  ;D
HJB
Re: Battery Water
« Reply #7 on: June 26, 2008, 11:11:56 PM »
Hi HJB,
Ok Thanks for the offer ... my ride 8 months niah ...  :pray: :pray: can tahan a bit longer....
Inflation up 8% ... pay the same ... I'm 8% poorer  :crycry: ...
Opps OOT  :zipped:
Re: Battery Water
« Reply #8 on: June 26, 2008, 11:19:36 PM »
Hmm i personally find that the traditional "water" type batter lasts longer for our hot humid climate. i think the sealed maintenance free batteries are made more for cold climate.
Re: Battery Water
« Reply #9 on: June 27, 2008, 12:32:22 AM »
I still prefer dry cell battery, hassle free, no need to worry about low level battery water.  :D
Krane
Re: Battery Water
« Reply #10 on: June 27, 2008, 09:38:48 AM »
Opps OOT  :zipped:
If I recall correctly, if battery dies within the first year, you can get free replacement from TC. So maybe you should pray it will die soon ...
HJB
Re: Battery Water
« Reply #11 on: June 27, 2008, 11:01:34 AM »
Haha .. I prefer better not ... having in mind the hazzle and lost of time if that happens.
Re: Battery Water
« Reply #12 on: June 27, 2008, 11:26:11 AM »
Surely cannot man babe!
Re: Battery Water
« Reply #13 on: June 27, 2008, 11:27:41 AM »
hi Silver,
distilled water (battery water)?
this is the water for "Coolant" that some of you guys mentioned in "Coolant" thread?
regards.
Re: Battery Water
« Reply #14 on: June 27, 2008, 12:00:10 PM »
Bro, distilled water (Transparent) is for the battery coolant (Coloured, green being the most common) is for the radiator, of course you can use distilled water in your radiator but no improvement to performance with a higher price but if you put coolant into your battery, the battery sure up lorry.
Re: Battery Water
« Reply #15 on: June 27, 2008, 12:07:48 PM »
Hi Golf,
Oh, that i know if we put coolant in the battery, sure go up lorry one.
What i am trying to say is that, for coolant-to-mix-with-water and the-water-we-put-in-Radiator, is that the distilled water that you guys mentioned in the other Coolant thread? Meaning, for coolant & radiator's water, it's advisable to pour in distilled water rather than water from the normal water tap? Pls correct me if i am wrong. I am confused with the water to use for Radiator & Coolant Reservior.
Regards.
Re: Battery Water
« Reply #16 on: June 27, 2008, 12:10:45 PM »
generally, normal tap water us used to dilute the coolant, can't remember what's the ratio. Using distilled water will not help in cooling down the engine faster.
Re: Battery Water
« Reply #17 on: June 27, 2008, 12:19:18 PM »
oh.
i see.
but, there are ppl saying that, not advisable to use normal tap water because of rusting or sthing? karat?
so, ok to use tap water? or must use distilled water for radiator and coolant reservior?
Re: Battery Water
« Reply #18 on: June 27, 2008, 01:05:57 PM »
hi Silver,
regards.
actually distilled water is used to top-up battery and so it is usually called battery water
however, in other thread, some prefer to use distilled water to also top up the radiator in the belief that it will not cause rusting
fyi, I had not topped up the water for the radiator/reservoir for almost 4 years for my previous car as the level had been near max for long time
Offline lyh1280
Re: Battery Water
« Reply #19 on: June 27, 2008, 01:18:31 PM »
As long we use "pure" water, it shall do the job in the battery or radiator.. distilled water is a pure 100% water, without any other content inside, esp minerals.. the other water we can use is RO (=reverse osmosis) which is also 100% pure water, only difference is the method they use to get the pure water, distilled is by boiling the water and collect the water vapours back by cooling, RO is by using membrane to filter out those minerals.. sort of.. :)
So u can actually go to supermarket and buy Distilled or RO water, just make sure it is 100% pure, no other minerals added inside from the ingredients stated on the label.. of cos, easiest to get Battery water fr petrol kiosk, which is consider cheap also la, usually $1/bottle.
Simple...
