Author Topic: Drive mode - D, D1, D2  (Read 12710 times)
Offline eclaire
« on: July 03, 2008, 10:52:12 AM »
hi guys, i would like to know what's the difference b/w the D modes?
Re: Drive mode - D, D1, D2
« Reply #1 on: July 03, 2008, 11:12:03 AM »
D1 is like your first gear and D2 is your second gear, these 2 are more for climbing or going down severe slopes which is seldom used in Singapore. D is like your third gear (with OD off, the yellow light on your meter is on) and 4 gear with OD on. I normally would play with the OD button when I merge traffic or when overtaking.
« Reply #2 on: July 04, 2008, 08:58:02 AM »
Some MSCP very steep too.  D2 may come in useful, though D also can go up but feel the car struggle a bit when full load.  Think OD effect kicks in only after certain minimum speed, else won't feel it.
Offline xuan511
  • Latio is a good car
« Reply #3 on: July 04, 2008, 09:16:05 AM »
bro 4AT don have OD mode rite? if have where isit?
Loving My Whitey
« Reply #4 on: July 04, 2008, 09:21:02 AM »
OD = OverDrive
it is automatically selected unless you activate the OverDrive Off function by pressing the button on the gearshift (on right side facing driver)
« Reply #5 on: July 04, 2008, 01:40:09 PM »
OD is the default mode when you select D in your 4AT. As mentioned, the OD off button is facing the Driver on the gear shifter. If you still don't know where is this, place your hand over the gear shifter in the most natural position, it's near your thumb.
« Reply #6 on: July 04, 2008, 09:38:25 PM »
Never bother to read manual izzit ?  :bleh:
« Reply #7 on: July 04, 2008, 11:56:29 PM »
If he still cannot find, just anyhow press till the OD word lit up. lol.
« Reply #8 on: July 05, 2008, 02:43:41 PM »
Use sparingly .  OD consumed lot of fuel
« Reply #9 on: July 05, 2008, 02:50:59 PM »
actually it is OD (OverDrive) Off that will increase fuel consumption .........
Offline ashocker
« Reply #10 on: July 05, 2008, 04:43:44 PM »
Erm, just wondering, coz the menu says to press brakes before changing gear - what about changing between the various D modes - do I have to brake to a complete stop before I can change between the different D modes?  :unsure:
« Reply #11 on: July 05, 2008, 05:34:16 PM »
That should be meant for when you are shifting out of P or N.
« Reply #12 on: July 05, 2008, 05:35:34 PM »
you only need to depress the foot brake pedal (and push button A - the top button on the right hand side of the gear selector lever) when you change from Park to Reverse
you do not have to be at complete stop when you shift down to lower gear
if you check the manual, there are speed limits whereby you must not change to lower gear otherwise engine may over-rev and cause engine damage
Position 2 is 100 km/h
Position 1 is 55 km/h
note : when you change from position 2 to position 1, you will need to push the button A
if not sure, you can read pages 5-9 to 5-12 of the manual (Printing : March 2009 (09) version)
hope these will help you
« Reply #13 on: July 05, 2008, 05:37:35 PM »
If used correctly it should reduce your FC, if you are merging and do not have enough power to merge properly, you'll need to slow down and later got tp pick up speed again, I believe this will use more petrol than if you merge at a higher speed thus reaching crusing speed at a shorter time.
« Reply #14 on: July 06, 2008, 02:10:44 AM »
Hi bro, this info regarding Position 2 & 1 really useful for me...did'nt know that there's speed limit for D2 & D1 as this is my 1st auto car...as you may guess, never flip my manual  :scared:... Thanks for your tip!  ;)
« Reply #15 on: July 06, 2008, 11:47:40 AM »
actually, will be good to read the manual
loads of info there
btw, did you read the manual for the sound system?
« Reply #16 on: July 06, 2008, 12:04:43 PM »
loads of info there
I have read but cannot find how to set the clock time and the clock show time even after we switch off engine.  :(
« Reply #17 on: July 06, 2008, 12:17:50 PM »
Hi Jazz,
What brand is your sound system (SS)?
Is it the one supplied by TC?
I had set mine (instructions in the SS manual) and it is ok.
When ignition switch is in off, clock is off.
Maybe, the key position is at Acc (2) whereby the electrical accessory power activates without the power turned on?
Silver
Offline xuan511
« Reply #18 on: July 06, 2008, 01:55:21 PM »
lol i know where is the O/D thing la, just nv try it onli. So the preset mode is O/D on? isit press and hold type or click-of-a-button type?
Loving My Whitey
« Reply #19 on: July 06, 2008, 04:35:35 PM »
Hi Jazz,
Silver
Yo Silver,
Mine is the default by JVC.
Yes, when the ignition switch is off, clock is off. But got 1 forumer requested his SE to activate to permanent on.
