Author Topic: Drive mode - D, D1, D2  (Read 12705 times)
Re: Drive mode - D, D1, D2
« Reply #20 on: July 07, 2008, 12:57:04 PM »
Yo Silver,
Mine is the default by JVC.
Yes, when the ignition switch is off, clock is off. But got 1 forumer requested his SE to activate to permanent on.
Hi Jazz, same JVC house brand as mine too...my clock will only activate when turn the acc key...the one with irritating sound when open driver's door yet wanna listen to radio... :scared:
Never knew that we can request SE to activate permanent clock...hmmm, can ask mine during next servicing... :w00t:
« Reply #21 on: July 07, 2008, 01:52:32 PM »
I have read but cannot find how to set the clock time and the clock show time even after we switch off engine.  :(
Hi Jazz,
Just to be sure, we are talking about JVC KW-XG506/KW-XG505.
Had done some checking.
Setting clock
Turn the ignition switch to position Acc (2).
Follow instructions on pages 17-18 which shows how to set clock.
(Clock H = Hour adjustment and Clock M = Minute adjustment)
Clock display
You can set the clock time to show on the display at all times when the power switch (on the SS unit) is turned off (the power switch is on the top left hand corner on the SS unit). However, the ignition switch must be in position Acc (2), ie, the car's electrical system must be set to deliver power to electrical accessories.
When the ignition switch is set to off, the clock display will not show at all.
However, when you press the DISP button, it will show the clock time for about 5 seconds irregardless of whether the power switch (on the SS unit) is turned on or off.
Hope this helps ..........
« Reply #22 on: July 07, 2008, 10:41:16 PM »
lol i know where is the O/D thing la, just nv try it onli. So the preset mode is O/D on? isit press and hold type or click-of-a-button type?
Press to off then press to on, that should be what is known as click of the button type?
Offline xuan511
  • Latio is a good car
« Reply #23 on: July 08, 2008, 09:21:43 AM »
ohhh finally went to explore the button. Haven tried the car off yet, maybe can try it tonight =D
btw for bros who is still not sure about overdrive:
Quote from Wiki:
"Overdrive can refer to two different things. An overdrive is a device which was commonly used on rear-wheel drive automobiles to allow the choice of an extra-high overall gear ratio for high speed cruising, thus saving fuel, at the cost of less torque."
Loving My Whitey
