Author Topic: Stale Smell from Aircon after parking for long time  (Read 10709 times)
Offline fickle
« on: August 14, 2008, 02:09:29 AM »
how do i get rid of the stale aircon smell from the first gush of air everytime i turn on my aircon (either in morning/afternoon/night) after parking for some time?    Its goes away after about 3-5 seconds though...
any suggestions would be most appreciated.  :)
Re: Stale Smell from Aircon after parking for long time
« Reply #1 on: August 14, 2008, 04:30:08 AM »
Most cars have this problem.   :smile:
You can change your air con filter or get your air con evaporator cleaned by the professionals. They will spray some kind of chemical foam on it.
http://y2u.co.uk/Really_Useful/Auto/Ru_Auto_016_Car_Auto_Air_Conditioning.htm
You can do an air con flush at -
http://www.htyre.com/AirCon%20Services.htm
Offline fickle
« Reply #2 on: August 14, 2008, 10:59:48 AM »
thanks for replying...
when the car comes straight from the factory, does it come with an aircon filter already?   or do i have to install my own?
Offline xuan511
  • Latio is a good car
« Reply #3 on: August 14, 2008, 01:38:00 PM »
Already comes with it, and each servicing they will replace 1 for u
Loving My Whitey
« Reply #4 on: August 14, 2008, 02:06:55 PM »
You sure Tan Chong will replace air con filter for you at every 10,000km servicing?
I thought it's at every 20,000km service interval?
And you have to pay for air con filter. It is not included in the package, not even for NPMP.
It costs $70+ I think.
Offline fickle
« Reply #5 on: August 14, 2008, 07:43:10 PM »
i'm confused... so is the air con filter included or not included in the NPMP servicing schedule ?
am not thinking of changing it myself at the moment cos my car is 2 months plus old...  a bit early to be changing aircon filter.
« Reply #6 on: August 14, 2008, 10:51:22 PM »
wow.. so EX to buy from TC one.. 70bucks for a piece of item!!
how much is our forum people selling>??? (stock filter)
« Reply #7 on: August 14, 2008, 10:57:15 PM »
Air Con Filter is NOT included in NPMP.
« Reply #8 on: August 14, 2008, 10:57:48 PM »
$18.00
Offline fickle
« Reply #9 on: August 14, 2008, 11:20:19 PM »
would changing to those 3m charcoal type remove the initial gust of "fresh air"?  :unsure:
« Reply #10 on: August 15, 2008, 11:40:35 AM »
got charcoal feet mat meh??? i tot only got charcoal cushion niah
i alos dont mind buying if there is a version for car mat
Offline fickle
« Reply #11 on: August 15, 2008, 12:35:46 PM »
i meant the charcoal aircon filter... to reducethe smell
« Reply #12 on: August 15, 2008, 01:20:15 PM »
The charcoal filter may restrict air flow, whcih means you may have to turn your air con fan speed to 2 instead of 1.
« Reply #13 on: August 15, 2008, 07:56:47 PM »
then might as well put charocoal in the car leh..............
i think charcoal filter also cant do much to get rid of the stale air ba.......>> air flow too fast leh
« Reply #14 on: August 15, 2008, 10:42:23 PM »
Guys/Gals,
You can try this if you have not done your cabin heater bypass, don't have to do it every day hoh, I do it once a while when I get the smell. Open all the doors, turn on your air-con, turn the heater up to max and air speed to max, let it run for about 5 minutes and switch the air mode around so that the hot air goes thru all the ducts for a short period of time.
Offline fickle
« Reply #15 on: August 15, 2008, 11:07:35 PM »
Guys/Gals,
hmm, how long would this normally last?
« Reply #16 on: August 19, 2008, 12:04:46 PM »
Huh? you mean they replace aircon filter for EVERY servicing. According to the maintenance booklet and the service report so far, this task isn't performed for 1000 and 5000.
Can someone pls clarifies?
Rgds
Offline aerosignal
« Reply #17 on: August 19, 2008, 12:18:22 PM »
Rgds
Don't mix up air filter and cabin air filter. Engine air filter is replaced during servicing and is part of NPMP or other heavy maintenance packages. Cabin air con filter is never part of any service package. Want them to change, they will ask you to take $140 aircon service package.
« Reply #18 on: August 19, 2008, 04:15:31 PM »
Do that for about 3 to 5 minutes. stay outside the car and bring the car back to about 30 deg before shutting down.
Offline fickle
« Reply #19 on: August 19, 2008, 04:18:28 PM »
:) i meant how long would this "treatment" keep the stale smell away from the car?
