Author Topic: car shakes when brakes are applied  (Read 10341 times)
Offline pseudo
« on: September 03, 2008, 02:28:41 PM »
hey all bros and sis,
can anyone advise on the above problem? could it be that the brake pads are worn out? also, the shake is more violent when i'm in D than in R. so could it be that my front wheels are misaligned? thanks very much in advance!
Offline vypez
    • need help with words?
Re: car shakes when brakes are applied
« Reply #1 on: September 03, 2008, 02:34:51 PM »
check rim nuts tightened in properly,
check wheel hub bearing,
check rotors, check brake pads.
check balancing.
cheers.
« Reply #2 on: September 03, 2008, 02:56:30 PM »
rotor warped would be my guess
Offline pseudo
« Reply #3 on: September 03, 2008, 03:29:50 PM »
check balancing.
cheers.
eh...can advise how to check them DIY?
Offline pseudo
« Reply #4 on: September 03, 2008, 03:31:30 PM »
so how much would i need to rectify the problem? the car still safe to drive or not ah?
« Reply #5 on: September 03, 2008, 03:49:15 PM »
when the wheel alignment is out will cause the steering wheel to vibrate when braking...as for your car shakes, it depends on the degree of shaking...it could also mean that the engine chasis is lose...............or i could be simply spoutting nonsense here.... :w00t:
« Reply #6 on: September 03, 2008, 04:02:19 PM »
how much i wont know. you can either:
1. change the rotor
2. send the rotor for skimming
But like i said, its only my guess, because usually when the car vibrates only when u brake, then chances are high is a warped brake rotor.
Offline aerosignal
« Reply #7 on: September 03, 2008, 07:56:29 PM »
1. check rim nuts tightened in properly: Only way is by using a torque wrench.
2. check wheel hub bearing: Unlikey because that one when driving will also have problems and usually will give off a humming sound.
3. check rotors, check brake pads: Don't think you can or want to check these yourself. But warped rotor can be caused by 1.
4. check balancing: This one most likely not also because affect you most when you are at speed.
How old is your ride? Tire rotated or changed recently?
If under warranty, bring back to TC.
Offline Keromond
« Reply #8 on: September 03, 2008, 10:32:57 PM »
actually mine also....when stopped...I can feel the car vibrate...howcome so many prob all coming one...only 2 weeks leh
Offline aerosignal
« Reply #9 on: September 04, 2008, 08:43:49 AM »
Car vibrating when stopped is not uncommon. Mine does that a bit too. It is because of the low idling rpm. Put to neutral and its gone right?
Offline pseudo
« Reply #10 on: September 04, 2008, 09:16:05 AM »
my car is slightly more than a year old. so the rotor and stuff still under warranty?
« Reply #11 on: September 04, 2008, 09:53:35 AM »
Warranty is 3 years or 100,000 km whichever come first.  :D
Offline pseudo
« Reply #12 on: September 09, 2008, 12:01:08 AM »
brought my car to TC toa payoh to check on sat. after about one and a half hour they called me to say the car is ready and everything is working well when they do the tests. so i went to collect my car and indeed everything is back to normal. but i highly doubt that my car has nothing wrong when i sent it in, just feel that they are hiding some problems from me leh.
« Reply #13 on: September 09, 2008, 12:07:16 AM »
As long problem solved.  :thumbsup:
Offline pseudo
« Reply #14 on: September 09, 2008, 12:09:32 AM »
haha yah. i still have 2 years to make noise if any problem surface again anyway.
« Reply #15 on: September 11, 2008, 11:52:05 PM »
Can the shake be due to the activation of the ABS? Is the shake felt only during hard braking?
Offline Keromond
« Reply #16 on: September 12, 2008, 12:24:09 AM »
I sent mine to Ubi...they say idling RPM too high...so tune for me...now slightly better. I asked anything wrong with Rotor...they say no..cos if got, when driving, the car will vibrate too..well, I just accept it  :unsure:
Bilancia
« Reply #17 on: September 12, 2008, 12:37:07 PM »
After reading the post, i personally think that its the uneveness of the rotor (Brake Disc) But we, Bilancia Intl Pte Ltd can actuaclly resolve this concern. No resolve, no nid pay.
48 Toh Guan Rd East
#01-111
Enterprise Hub
Offline pseudo
« Reply #18 on: September 16, 2008, 11:03:39 PM »
that was what the mechanic told me. but i told him that i just brake normally and it shakes.
Offline RG
« Reply #19 on: September 17, 2008, 12:31:04 AM »
i did experianced it once.., be it normal braking or hard braking. can feel it on the steering.. but after i changed my brakes problem resolve... ;D
