Author Topic: 5th service with TCM, Package A?  (Read 16939 times)
« on: September 15, 2008, 04:52:16 PM »
I logon to nissan.com.sg, the package A is $90.62/= without Engine Oil, I may bring my own Filter.
with the following services rendered. Worth?
Job Pricing
Job Code: MPAN
Job Desctiption:  **MAINTENANCE SERVICE PACKAGE A**
(EXCLUDE ENGINE OIL)
Job Price:  $90.62
LUBRICATION & OIL CHANGE SERVICE
>change engine oil / oil filter & drain plug washer
CHECK & TOP UP TO LEVEL
>brake / clutch / power strg fluid
>auto or manual transmission / differential & axle oil / h-cvt / lsd
>engine coolant / washer tank / battery water
CLEAN & LUBRICATE
>door hinges, locks, catches & battery terminals
>clean air cleaner element
INSPECTION- EXTERIOR, UNDERHOOD, SUSPENSION,
>check all tyres including spare tyre & pressure settings
>rotate / balance frt tyres (additional charge)
>external lighting system / room lamp / horn {bulbs extra charge}
>wiper function, adjust spray nozzle angle
>power strg gear & linkage, hoses & pipes
>all drive beltings / adjust tension {renewal -
Notes:
additional labour & material charges}
>drive shaft dust covers / propeller shaft / axle
& suspension parts
STROKE & OPERATION
>check brake pad / shoes thickness {renewal - additional labour & material charges}
>check brake master pump / other brake components
>radiator hoses condition / fuel hoses & pipes
>all engine mountings / transmission mountings / exhaust system
>pressure test cooling system / check coolant mixture ratio @40,000km
>test batteey condition & charging rate
ENGINE & ELECTRICAL
>electronic engine tuning with engine analyser & system interrogation
>check fuel injection a/f valve {additional labour charges if service is require}
>adjust idling, co level & ignition timing
>inspect spark plug {renewal - additional material charges for package a & b}
>inspect 02 sensor {exhaust gas sensor} / ignition wires
**SERVICE ITEM & PRICES SUBJECT TO CHANGES WITHOUT
service apply. tan chong motors sales pte ltd reserve all rights.
Re: 5th service with TCM, Package A?
« Reply #1 on: September 15, 2008, 05:34:10 PM »
http://www.autosaver.com.sg/nissan.html
The same package at Autosaver with synthetic oil costs you just an extra $7.38 at $98
« Reply #2 on: September 15, 2008, 05:45:56 PM »
Just did my service at autosaver for 70k which is equivalent to TCM Package A.
it is $98 - own engine oil $45 = $53.
By the way both package does not include Tyres rotations, so i think
TCM charge $20, autosaver charge $15 (use nitrogen)
Finally i pay 53 + 15 + 7%gst = $71plus.
Offline rocket
« Reply #3 on: September 16, 2008, 12:11:36 AM »
for 30k, 50k and 70k service, I just bring my own Engine oil and do the srvice in outside workshop,
oil change and basic check and top up just for $20 only.
« Reply #4 on: September 16, 2008, 10:54:09 AM »
hi clarence,
so cheap? worth and good EO?
« Reply #5 on: September 16, 2008, 10:55:43 AM »
Hi robtan99
So autosaver is good then?
Where you buy ur EO? What brand?
Regards.
« Reply #6 on: September 16, 2008, 11:00:13 AM »
Hi guys
Autosaver got shop at 48 Toh Guan Road East, Enterprise Hub?
Near Jurong is it?
« Reply #7 on: September 16, 2008, 11:10:55 AM »
hi clarence,
Autosaver uses fully synthetic Rev 1 engine oil. It's their in-house brand, just like Tan Chong's Fasflo.
If you want to use either Mobil 1 or Amsoil, just top up an extra $20, so total servicing cost = $118.
Still cheaper compared to Tan Chong's $180 using their in-house engine oil, Fasflo.  :D
The $62 savings can get you a full tank of 95RON petrol.  :thumbsup:
« Last Edit: September 16, 2008, 11:13:02 AM by clarence »
« Reply #8 on: September 16, 2008, 11:39:28 AM »
Hi clarence,
Meaning i can get Amsoil from Autosaver when I do my servicing there? I don't have to purchase my own b4 going to Autosaver? Meaning autosaver does supply Amsoil aso (upon request?) We topup another $20 to get that?
Regards.
« Reply #9 on: September 16, 2008, 11:41:02 AM »
Hi clarence,
Regards.
Yes, you are absolutely correct!  ;D
« Reply #10 on: September 16, 2008, 11:49:38 AM »
hi clarence,
SUI!!!
i dun want to bother to go where to buy this & that... i want hassle FREE!!! :(
u r sis right? u going for servicing aso? can meet u there leh? :) (hey guys, dun say i Buaya hor, we are friends mah...)
regards.
« Reply #11 on: September 16, 2008, 11:51:38 AM »
Hi clarence,
Actually, we topup $20 to get 3 bottle of Amsoil or autosaver just responsible to pour amsoil EO to our EO tank till the reasonable level and we dont need to keep the 'backup' amsoil for topping up ourself (if below the level?)
So far, my Mobil1 the spare EO, till now still never use coz the level still at the same level, not reducing!
« Reply #12 on: September 16, 2008, 11:55:07 AM »
If I go servicing with you, you pay for my servicing?    :D   :bleh:
I just sent my car for servicing 2 weeks ago.
You should have said earlier.   ;D
« Reply #13 on: September 16, 2008, 11:56:04 AM »
Hi clarence,
Autosaver will pour amsoil EO to your EO tank till the reasonable level and you don't need to keep the 'backup' amsoil for topping up.  :thumbsup:
« Reply #14 on: September 16, 2008, 11:57:15 AM »
hi clarence,
SUI!!!
regards.
If top up $20, I prefer Mobile1 gold cos more expensive than Amsoil.
BTW.  :nobuaya:
« Reply #15 on: September 16, 2008, 11:58:42 AM »
I never said it's Mobil 1 GOLD.
It is the silver bottle Mobil 1 which is good enough.
It comes with the latest SPI rating.
« Reply #16 on: September 16, 2008, 12:03:13 PM »
Hi clarence
2wks ago? I wasn't around leh and not convenient and have not reached my mileage yet.
Gui ge advised me to hit 30k then go for next servicing, now is 28200, so odd the number. Hard to remember.
Regards.
« Reply #17 on: September 16, 2008, 12:04:21 PM »
Hi clarence
Sui... Good answer you have provide.
Is good for Autosaver also as they will always have "balance" in the last bottle for the next car hehe. BUT, if that bottle is OPEN for too long period, no good right?
Thanks.
« Reply #18 on: September 16, 2008, 12:04:48 PM »
What's so hard to remember?  :unsure:
Service every 10,000km.
« Reply #19 on: September 16, 2008, 12:06:03 PM »
or 3 mths (on avg)
