Author Topic: Road noise increase after serving..  (Read 12565 times)
Offline baobao
« on: September 16, 2008, 08:04:50 AM »
Just sent my car for 1k serving yesterday but noticed the road noise sound increase..
is it normal??   :confused1: :confused1:
Re: Road noise increase after serving..
« Reply #1 on: September 16, 2008, 11:00:59 AM »
My ride aso can hear noise road noise this 2 days.
Donno why.
May be is the tyre pressures?
Offline vypez
    • need help with words?
« Reply #2 on: September 16, 2008, 11:34:54 AM »
check tire pressure.
most prob is tan chong adjust your pressure to a lower one.
« Reply #3 on: September 16, 2008, 11:41:47 AM »
Hi vypez,
Oh, i have not gone for servicing yet.
I went HK last wk, the car wasn't move for abt 6 days. the tyre pressures went hilang is it possibly coz of this?
« Reply #4 on: September 16, 2008, 11:50:56 AM »
Could be due to low tyre pressure or flat spot on tyres, whcih also means your tyres need to be replaced.
Flat spot occurs when a car's tyre is rested on the same spot for a prolonged period.
« Reply #5 on: September 16, 2008, 11:52:26 AM »
Hi clarence,
sure or not? 6 days not driving it only leh?
« Reply #6 on: September 16, 2008, 12:02:40 PM »
Hi clarence,
lunch time go pump "hong" lor.  :smile:
« Reply #7 on: September 16, 2008, 12:03:42 PM »
Since your car is still under warranty, better to send back to Tan Chong to check.
I cannot confirm the actual problem unless I test drive your car.
You can also run your hands round your tyres and feel for any flat spot.
If you got YOM2007 Latio, bear in mind that the tyre had been resting on the same spot in the warehouse for a year.
« Reply #8 on: September 16, 2008, 12:15:14 PM »
Hi clarence
Go TCM to chk? Tyre under wrty ? Now mileage abt 27800km. I never go TCM for my 4th service leh, if suddenly go back there, will they TL or not?
I don't mind to let u test drive my car. Where convenient to meet arh? (Jazz, no buaya here hor... test drive only)
Regards.
« Reply #9 on: September 16, 2008, 12:16:10 PM »
Hi clarence,
How does it feel (for the flat spot)?
Offline rongshu
« Reply #10 on: September 16, 2008, 12:17:59 PM »
I feel after pump tyres to 230/210, the road noise increases. It will become quiet after a few days of driving. anyone feel the same or it is just me...
« Reply #11 on: September 16, 2008, 12:18:39 PM »
Hi clarence,
flat lor
hehe
like airport
:P
« Reply #12 on: September 16, 2008, 12:30:14 PM »
Hi clarence,
pun chek.  :D
« Reply #13 on: September 16, 2008, 12:38:30 PM »
flat lor
hehe
like airport
:P
hi detach8,
ic. hahaha, i got it. 扁扁 平平? :)
well, depend on what kind of 'flat' we are talking abt, if tyres aso flat already, that is no good! some other things if too flat, is no good too. i believe u guys will aso agree with me?
pun chek.  :D
hi jazz,
got u.
« Reply #14 on: September 16, 2008, 12:41:59 PM »
Hi rongshu
榕树
榕树下? Nice song.
Hi guys,
well, abt the pumping of air to our tyres, i experienced a few times, when i pumped at ESSO Mobil at Clementi, the pump, donno why when i pump it, it's actually the other way round i.e. the air came out from the tyres instead of going into the tyres.... i donno how.... i try to adjust at the air pump the psi by releasing the current setting (or sthing like that, forgot what i did), then i re-pump again, the air then can go into the tyres... Why so?
Thanks.
Regards.
« Reply #15 on: September 16, 2008, 01:04:01 PM »
The new electronic pump actually releases air from your tyres if it is overinflated.  :thumbsup:
Eg. If you set it to 230KPa, it will release some air from your tyres if their pressure is higher than 230KPa.
« Reply #16 on: September 16, 2008, 01:38:56 PM »
Is it better to pump ur tyre according to spec as 230/210? After my 13.7km/litre feat...i can't seems to achieve it anymore..nowadays between 12.5 to 13.5....then my hubby suggest to go check out the tyre pressure at petrol station. So we set front 230 and rear 210....then was suprise to see tat air was released from rear....wondering if TM messed with the pressure when they do my 1k servicing or not...
 :crycry:
« Reply #17 on: September 16, 2008, 02:04:39 PM »
That means Tan Chong pumped more air into your tyre (above 210KPa).
Nothing wrong with that.
You just get a more bumpy ride.
« Reply #18 on: September 16, 2008, 02:31:51 PM »
Hi clarence,
Oh, meaning, when i pump that time, the tyres are having Heat, so it is having higher pressure? So, when i setup to 230 for front tyres, it releases air from my tyres? If so, i cannot pump air in the evening after travelling for 20km then? best time shld be in the morning of evening (a few min after i drive off the car?)
« Reply #19 on: September 16, 2008, 03:32:25 PM »
What I did not understand is why they did it? Itcy hand can't be scratched? Please tell me if this is true...if u pump too much air to ur tyre...it actually will be less dragy on roads thus improves FC but more prone to punch-chik....if less air...more grip on the road but consume more petrol...
