Author Topic: Timing belt or timing chain?  (Read 15396 times)
Offline gunner1976
« on: January 07, 2009, 12:26:25 AM »
Dear fellow Latio Owners,
Could u guys clarify whether Latio is running on belt or chain? My understanding was running on "Timing Chain" till one of my friend bought his car to service at Autosaver. The mechanic told him that the "timing belt" needs replacement.
Other than the fan belt and water pump (normally replaced together), are there any more "belts" that need replacement over time?
Pls advise.. Thanks
Offline zzyzx
Re: Timing belt or timing chain?
« Reply #1 on: January 07, 2009, 01:12:44 AM »
The latio is using timing chain FYI.
« Reply #2 on: January 07, 2009, 11:45:31 AM »
The only belt that needs to be changed is the alternator belt, which is also the air-con belt and it should be replace at 60K. Mine was shredded before it reaches 60K.
Offline gunner1976
« Reply #3 on: January 07, 2009, 12:11:44 PM »
Yup...
my friend latio mileage is 65000km.. however Autosaver told him is timing belt...confusion here.
He was charged $90.
How much did you pay for it?
Offline westresting
« Reply #4 on: January 07, 2009, 01:14:58 PM »
I don't think it is Timing belt, because changing timing belt cost more than $90.00. It cost more than $300.00 at least.
« Reply #5 on: January 07, 2009, 01:19:49 PM »
Timing belt is cheap. It is the labour costs that kills.
« Reply #6 on: January 08, 2009, 12:33:35 PM »
Is it included under Autosaver $800+ service package?
« Reply #7 on: January 08, 2009, 05:57:47 PM »
Think is the term use, the mechanic know is a chain, but when converse, people usually classified as timing belt instead of the uncommon term timing chain.
Offline Indignant
« Reply #8 on: January 06, 2011, 10:45:20 PM »
Apologies for digging up an old thread. Anyone knows how much it cost to change out timing chain?
Offline ccsSGM
« Reply #9 on: January 07, 2011, 06:58:18 PM »
Chain No need to change
Can last till scrap
Offline david1881
« Reply #10 on: January 07, 2011, 09:26:52 PM »
Timing chain will need to change, but at a much longer mileage than timing belt.  The chain will give tell tale warning signs when change is needed.  Unlike timing belt just snap without warning.
Offline Indignant
« Reply #11 on: January 07, 2011, 10:09:29 PM »
What kind of tell tale signs? Any example?
« Reply #12 on: January 08, 2011, 09:18:09 PM »
About a month ago, my car will have a chi chi sound after cranking, went back to TCM, they just tighten my timing chain plus lubricant and the problem solved.
Offline rodrigue
« Reply #13 on: January 09, 2011, 09:38:31 AM »
anyone knows if the timing chain is assessible by user? i wana lubricate it...
thks
« Reply #14 on: January 09, 2011, 11:02:58 PM »
It's inside the engine and I think it's quite well lubricated.
Offline david1881
« Reply #15 on: January 11, 2011, 08:32:50 AM »
Timing chain is well lubricated by engine oil.
There should be a spring tensioner that will maintain the chain's tension.  I wonder....  :confused1:
A common tell tale sign is the chain noise for chains that are beyond tightening or adjustment.
« Reply #16 on: February 13, 2011, 11:43:53 PM »
there's no need to change the timing chain,unless u never change ur engine oil ,late change or never change of engine oil will cause the oil to turn into sluge,this will block the oil channel and cause the engine moving parts to burn up.what they change for you is the drive belt (alternaor,air con compressor and the water pump)only 1pc to drive all three components.
« Reply #17 on: February 15, 2011, 11:27:18 PM »
thks
ONLY DRIVE BELT CAN BE LUBRICATED NOT TIMING CHAIN ;)
