Author Topic: isit bad for engine if your car is not moving with engine on?  (Read 9421 times)
Offline kennytoh
« on: February 23, 2009, 12:14:11 PM »
everyday i will normally spent 30min to 1hr waiting for my gf n simply just parked my car at the carpark while i rest inside with the engine on.
i understand that it is waste of petrol, but is it bad to the engine when your car is not moving but with engine running?
yest my frz told me is very bad for the engine as it generate heat n since the car is not moving, there's no "cooling" system frm the wind. in a long run, is very bad for the engine...isit true?
Offline skxly
Re: isit bad for engine if your car is not moving with engine on?
« Reply #1 on: February 23, 2009, 01:18:21 PM »
Solution: get a gf who is punctual  :D
Joke aside, you run the risk of carbon monoxide poisoning if you keep the aircon on for so long while stationary (exhaust fume may flow into the cabin).
I don't think it is a problem to have the engine running but rather just a waste of fuel and wear on your engine, engine oil, radiator, etc .... achieving nothing except keep you warm.  My recommendation is to shut the engine while waiting - friendlier to mother earth too!
« Reply #2 on: February 23, 2009, 04:55:08 PM »
Nothing bad to your engine, there is a radiator fan to cool your engine if station too long when the temperature build up. Rather your battery life will be shorten since alternator is not running, so AC and radio all generate power thru your battery.
Offline Gone with the wind
« Reply #3 on: February 23, 2009, 11:17:26 PM »
Yes, it is very bad to your engine.  Your engine will be heat soak and your engine oil will be degraded faster than normal, thus reduce the protection.  Besides, it will accumulate more carbon in your exhaust system, because there is no loading when the car is station.  Even your radiator hose and all the rubber components inside the engine compartment will be soaking in the heat and caused damage sooner than normal usage.  Do you feel that your car always feel more lethargy whenever caught in a bad traffic jam?
Most important is this will contribute to global warming!  With the engine idling, it generated additional heat and produce carbon monoxide, not only consume additional natural resources like oil.  Everyone should turn off their engine if they are waiting for more than 1 minute in the car park.  This will not only save you money, it is also responsible to our mother nature.  Something you might also want to consider, this is also a safety precaution because you do not know whether there is any leakage in your exhaust system that might leak the carbon monoxide into your car cabin, and the result can be fatal over long period!
Last word of advice, leaving the engine running in the car park for long period (I can not remember exact timing, could be 5 minutes) is actually against the law.  The NEA officer can summon the driver for polluting the environment.
So there are more cons than pros.  Let's do the right thing by switching off our engine whenever the waiting is more than 1 to 2 minutes.  We can always wind down the windows for better air circulation, park our car under the shade, or even get out of our car and wait at nearby shaded areas.
I hope everyone can adopt the right practice and make our world a better place to live. :thumbsup:
« Reply #4 on: February 25, 2009, 12:29:31 AM »
Diesel engines no prob dun say on for 1 hour, engine left idling for 6 hrs oso bo taichi... Petrol engine not advisable to do so.
« Reply #5 on: February 25, 2009, 09:28:19 AM »
alternator not running when the engine started but car stationary?
« Reply #6 on: February 25, 2009, 02:47:10 PM »
To the best of my knowledge, once the engine is running, the alternator should be operating as well, irregardless whether the car is stationary or moving.
You may wish to send your Latio for a check up if your alternator is not operating when your car is stationary. I believe the alternator is covered under warranty.
« Last Edit: February 25, 2009, 02:49:17 PM by clarence »
« Reply #7 on: February 25, 2009, 07:04:31 PM »
Sorry my bad, was replying when thinking engine is not cranked. To further explain, alternator is running when engine is cranked but if the car is stationary, assuming TS on radio and AC while waiting for his GF, the supply current drawn is overload than the alternator able to supply because if the acceleration is not depressed, but will compensate by a voltage regulator, the voltage regulator operates by modulating the small field current in order to produce a constant voltage at the stator output, it also regulates the alternator's output voltage by varying the amount of current in the stationary exciter field coils. So if the alternator need to supply more current to the battery, it will indirectly generate more heat which the engine bay is already heated up, thus the lifespan of the alternator will be shorten in the long run which directly affect the battery life as well.
In summary, your alternator and battery will be prone to shorter lifespan rather than your engine if the car is operating in stationary mode.
« Last Edit: February 25, 2009, 07:08:08 PM by Jazz »
Offline kennytoh
« Reply #8 on: February 26, 2009, 12:32:06 AM »
wow..seem so technical.
but really thanks alot for the replies from everyone.
think next time i better off my engine or just open the window instead.
« Reply #9 on: February 26, 2009, 08:34:34 AM »
Do this for long period, makes your servicing based on  mileage inaccurate. That's just my opinion.
Offline vortex
« Reply #10 on: February 26, 2009, 02:16:09 PM »
It is also illegal to let the engine running while waiting. The NEA will fine you for polluting the air.
