Author Topic: rpm is 1400rev/min  (Read 6270 times)
rpm is 1400rev/min
« on: February 28, 2009, 03:59:38 PM »
just go my EO changed at my 10K servicing last sat. Used the FOC Fastflo from TCM
BUT after 6 days of using the EO, my engine rpm is still at 1400rev/min when i start my engine (P-mode), 900 rev/min when in D-mode
After driving off, the rev will drop to 900 then after driving for a while, if i put the car to P-mode again, the rev will be around 800-900 rev/min
Is this normal after 10K servicing??
previous, the rpm for P-mode is around 800-900rev/min  ANY TIME leh...
Offline idiotboi89
Re: rpm is 1400rev/min
« Reply #1 on: February 28, 2009, 04:48:07 PM »
hmm my car also 1.4k rpm while warming car engine...
hope tat helps
« Reply #2 on: February 28, 2009, 04:50:17 PM »
what's the RPM in Neutral at the end of a reasonably long journey?
« Reply #3 on: February 28, 2009, 06:24:49 PM »
Perfectly normal and no cause for concern.
The high rpm during a cold start is the ECU's signal to the engine to hasten the proces of warming up the engine to operational temperature.
That's why when engine is warmed up, idling rpm drops to normal 800rpm.
melvinhgf
« Reply #4 on: February 28, 2009, 10:20:22 PM »
Yup, i've asked the people at TCM Ubi. He says its normal for the rev at cold start as long as it is below 2k.
he explained that because the engine (some fuel injection type or watsoever) is actually releasing fuel to burn so that the temperature is wamed up. y below 2k? cos tats the jap govt's limit..  :confused1:
i'm still on fastflo organic EO waiting for 5K servicing. limck007, u sure u din see wrongly before the EO change?
at first i tot is becos i installed the O2 charger and reprogramme my ECU. but no it isnt because of these mods. The TCM guy says as long as the rpm goes back to 800 range (same for other cars) after warm up, then the engine is ok. During warming up, if the rev is more than 2k, then something is wrong.
Regards
« Reply #5 on: March 02, 2009, 09:21:04 AM »
yah leh.. b4 the Eo change .. my starting rev is around 900rpm/min leh... never hit 1200 at P mode..
but since its normal... then okie loh.. Maybe is the EO ba
« Reply #6 on: March 04, 2009, 05:39:32 PM »
hello 007
this is normal rite?
« Reply #7 on: March 04, 2009, 07:40:08 PM »
yupyup
normal =D
Offline quirky
« Reply #8 on: February 07, 2011, 10:25:42 AM »
Old thread, but...
Last time, idling rpm used to be around 800 when I start car in the morning (Been this way for over 2 years).
Since last week, the rpm after starting the car has risen to 1,200!
Could it be the recent cold weather? :D
Offline hwlee
  • Honda
« Reply #9 on: February 07, 2011, 10:38:22 AM »
Latio's on idle RPM is around range of 700-800... Start up RPM will always higher than that range cos your car's engine is cool (common for all type of vehicle).
idle RPM can only be captured after your car was totally warm up (Engine Cool Indicator Light is off and aircon is off and car engine started after few minutes). Gear on P or N is preferred.
« Reply #10 on: February 07, 2011, 04:16:59 PM »
What's the normal rpm when the car is fully warmed up?
Mine is hovering at 600-700rpm at D.
« Reply #11 on: February 07, 2011, 10:47:46 PM »
my one is ard 900
Offline quirky
« Reply #12 on: February 09, 2011, 10:46:57 PM »
I remember seeing mine at 800 when I just start the car.
Another question, at what rpm can you all hear the engine? Mine stays quiet until about 2,500rpm. Is this consistent?
