Author Topic: Ikey Door button problem  (Read 12768 times)
moshi2008
« on: June 10, 2009, 11:47:13 AM »
Hi guys, have you all encounter problem like your Ikey door button when press, it could not be opened. i had situation like this and was only when i pressed the 3rd time then the door unlocked. kindly advise thanks :confused1:.
Re: Ikey Door button problem
« Reply #1 on: June 10, 2009, 11:55:20 AM »
HI!
sometime i m having this problem as well. think mayb is the ikey battery weak oridi. how old is ur car?
« Reply #2 on: June 11, 2009, 08:01:23 AM »
mine happen when wanted to lock the car. then have to on and off engine again, then it will work. car abt 8 mths.
« Reply #3 on: June 11, 2009, 09:47:09 AM »
My car slightly more than a year old and did not encounter this problem. I can still unlock/lock my car from 11th storey of my HDB flat (line of sight between Ikey and car).
Have you noticed a "shortening of distance" to lock/unlooad when using your IKey? If yes, may consider a battery change on Ikey. Else, complain to TCM to get the components checked.
Offline priyana
« Reply #4 on: June 11, 2009, 10:15:14 AM »
Happens to me when I put my handphone in the same pocket as my iKey.
It was worse with a pager (back 3 years ago).
Somehow the radio frequency might be interfering with the iKey.
« Reply #5 on: June 11, 2009, 10:40:58 AM »
you means from 11th storey can unlock/ lock your car via Ikey?  that is amazing
melvinhgf
« Reply #6 on: June 11, 2009, 11:37:37 AM »
Me too... when the 2 things are put together, i cant open my car door!!
I read it in the manual that says that radio frequency from phones can interfere with the radio frequency of th i-key. so i put them in separate pockets. :-)
« Reply #7 on: June 11, 2009, 11:51:05 AM »
RFID Frequencies from the Esso and Mobil petrol kiosk is also causing lots of jamming to our I-key.
« Reply #8 on: June 11, 2009, 12:03:57 PM »
Yes, mindman. There is no obstruction (ie clear line of sight).
cheers,
« Reply #9 on: June 11, 2009, 04:16:07 PM »
yeah the service adviser says certain models of mobile fone can cause interference to our I-key if put inside the same pocket or handbag.
Wah 11th storey so power ah?! wat brand of batt u use for ur I-key siah?
moshi2008
« Reply #10 on: June 13, 2009, 06:54:11 PM »
my car is only 10 day old  :D. guess alot of you had encounter this problem. is it possible that stuff like a plastic cover will block the ikey operation  :confused1:
Offline hammer99
« Reply #11 on: June 13, 2009, 07:08:15 PM »
Most likely your IKEY battery is weak. Well I guess your 10 days old car is using an old battery; or your stock IKEY is in the warehse a long time.
pchmj
« Reply #12 on: June 14, 2009, 08:42:49 AM »
Does the ikey console light blink when you just start your engine? Mine flashes and I thought the ikey is faulty but actually it's low batt warning signal.
melvinhgf
« Reply #13 on: June 25, 2009, 02:23:05 PM »
i dun think a plastic cover will affect. I put my i-key in the leather pouch provided by tan cheong since day 1. Some times the i-key is placed in my bag (so extra layers of fabric) but there is no issue with the usage
moshi2008
« Reply #14 on: July 04, 2009, 10:33:54 PM »
hi guys, drive my car for 1 month and sometime still face this problem. However i already get use to it. went to my first servicing and told them about this thing. they checked and said that my i key system was ok. i wonder how they checked at the first place? :confused1:
Offline Gone with the wind
« Reply #15 on: July 05, 2009, 11:06:22 AM »
I faced the same problems only recently.  It took me 2 to 3 attempt to lock and unlock the car.  I measured the Ikey battery, the battery still had more than 3 volt in there.  I proceed to change to new battery, the problems did not go away.  My latio is only 6 month old.
I am going to contact TCM ask them to fix the problems.
Offline rongshu
« Reply #16 on: July 06, 2009, 05:26:47 PM »
No wonder I have problem locking my car at Esso.  Have to press door button at least 2 times.
moshi2008
« Reply #17 on: July 08, 2009, 12:48:07 PM »
had told them about this problem during my first servicing. they told me that they will check but in the end no faulf found. i really wonder how they check our i key system :confused1:
Offline leolooi
« Reply #18 on: July 08, 2009, 01:54:10 PM »
if the Ikey no batt wan do batt replacement cost how much?
« Reply #19 on: July 08, 2009, 03:30:00 PM »
D.I.Y=$1.50
If ask ppl replace batt for u=$9
